Visitor mtislam
Emulation HW kernel link failed
When I try to build a project for Emulation HW, kernels are complied with no error but an error is given during the linking stage as below:
ERROR: [XOCC 60-399] xclbinutil failed, please see log file for detail
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
The LOG is attached.
Then I tried System build which finishes without any error and system is working correctly on the board & host.
Why I am getting error in Emulation-HW when there is no error in system?
Note: I am using VCU1525 Virtex UltraScale+ FPGA.
Tags (3)
Re: Emulation HW kernel link failed
@mtislam
Is this on Ubuntu machine with 2019.1? If yes, try installing csh to run hw_emu:
“apt install csh”
--Syed
Visitor mtislam
Sorry I forgot to mention it is SDx 2018.3 running on Ubuntu 16.04
