Error: Failed to create compute program from binary -44!
I just installed 2017.2 on my linux system: Ubuntu 16.04.4 LTS; System Kernel :4.4.0-134-generic
And met the following error:
root@msl-dsma-dev56:/opt/Xilinx/xil-accel-rd-ku115/xbinst/test# ./verify.exe ./verify.xclbin
Linux:4.4.0-134-generic:#160-Ubuntu SMP Wed Aug 15 14:58:00 UTC 2018:x86_64
XILINX_OPENCL="/opt/Xilinx/xil-accel-rd-ku115/xbinst"
LD_LIBRARY_PATH="/opt/Xilinx/xil-accel-rd-ku115/xbinst/runtime/lib/x86_64:"
CL_PLATFORM_VENDOR Xilinx
CL_PLATFORM_NAME Xilinx
loading ./verify.xclbin
ERROR: Failed to load xclbin
Test failed
When try to dmesg I found:
MIG Calibration failed after bitstream download /tmp/9313/0/driver/xclng/mgmt/mgmt-bit.c:816, err: -110
Any hint will be appreciated.
Re: Error: Failed to create compute program from binary -44!
UBUNTU 16.04.4 is not supported with SDx 2017.2
Please refer supported OS https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1238-sdx-rnil.pdf
Yash
P.S. UBUNTU 16.04.4 is supported with latest SDx
Yash
I have the same problem with SDx 2018.2 in Ubuntu 16.04 LTS
Do you know the solution?
varinic@varinic:/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/test$ ./verify.exe verify.xclbin
Get 1 devices
Using 1th device
loading verify.xclbin
Test failed
