Observer rampage
Error compiling SDSOC project
I am compiling an SDSOC project. Platform files are given by the merchant. This error occurred during compilation.
There is no solution.
The error message is as follows:
INFO: [SDSoC 0-0] Analyzing hardware accelerators...
INFO: [SDSoC 0-0] Analyzing callers to hardware accelerators...
WARNING: [SDSoC 0-0] Unable to determine the memory attributes passed to input of function white_balance at C:/Users/huangjianhua/test/new3/src/main.c:134
INFO: [SDSoC 0-0] Currently, #pragma SDS data mem_attribute is specified to be: PHYSICAL_CONTIGUOUS, please make sure this is correct
INFO: [SDSoC 0-0] Scheduling data transfer graph for partition 0
INFO: [SDSoC 0-0] Creating data motion network hardware for partition 0
INFO: [SDSoC 0-0] Creating software stub functions for partition 0
INFO: [SDSoC 0-0] Generating data motion network report for partition 0
INFO: [SDSoC 0-0] Rewriting caller code
INFO: [SDSoC 0-0] Removing implementation files from previous run C:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi
INFO: [SDSoC 0-0] Creating block diagram (BD), address map, port information and device registration for partition 0 (this may take a few minutes)
system_linker started at Thu Jan 24 19:47:43 +0800 2019
CRITICAL WARNING: [Project 1-505] Unrecognized Option Name DSANumComputeUnits
INFO: [SDSoC 0-0] See C:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/vivado.log for the context of the Vivado message above.
CRITICAL WARNING: [Project 1-505] Unrecognized Option Name XSimRadix
CRITICAL WARNING: [Project 1-505] Unrecognized Option Name XSimTimeUnit
CRITICAL WARNING: [Project 1-505] Unrecognized Option Name XSimArrayDisplayLimit
CRITICAL WARNING: [Project 1-505] Unrecognized Option Name XSimTraceLimit
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_clk_wiz_0_0/snowleo2_clk_wiz_0_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_clk_wiz_0_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_clk_wiz_0_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_clk_wiz_1_0/snowleo2_clk_wiz_1_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_clk_wiz_1_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_clk_wiz_1_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_pldma_rgbin_0_0/snowleo2_pldma_rgbin_0_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_pldma_rgbin_0_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_pldma_rgbin_0_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_pldma_rgbout_0_0/snowleo2_pldma_rgbout_0_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_pldma_rgbout_0_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_pldma_rgbout_0_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_proc_sys_reset_0_0/snowleo2_proc_sys_reset_0_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_proc_sys_reset_0_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_proc_sys_reset_0_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_proc_sys_reset_1_0/snowleo2_proc_sys_reset_1_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_proc_sys_reset_1_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_proc_sys_reset_1_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_proc_sys_reset_2_0/snowleo2_proc_sys_reset_2_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_proc_sys_reset_2_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_proc_sys_reset_2_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_proc_sys_reset_3_0/snowleo2_proc_sys_reset_3_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_proc_sys_reset_3_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_proc_sys_reset_3_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_ps7_0/snowleo2_ps7_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_ps7_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_ps7_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_xbar_1/snowleo2_xbar_1.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_xbar_1'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_xbar_1'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_xbar_0/snowleo2_xbar_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_xbar_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_xbar_0'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_auto_pc_2/snowleo2_auto_pc_2.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_auto_pc_2'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_auto_pc_2'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_auto_pc_1/snowleo2_auto_pc_1.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_auto_pc_1'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_auto_pc_1'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_auto_pc_3/snowleo2_auto_pc_3.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_auto_pc_3'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_auto_pc_3'. Error reading project file(s).
CRITICAL WARNING: [IP_Flow 19-182] Failed to load BOM file 'c:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/snowleo2.srcs/sources_1/bd/snowleo2/ip/snowleo2_auto_pc_0/snowleo2_auto_pc_0.xml'.
CRITICAL WARNING: [IP_Flow 19-183] Failed to load IP instance 'snowleo2_auto_pc_0'.
CRITICAL WARNING: [IP_Flow 19-1835] Failed to recreate IP instance 'snowleo2_auto_pc_0'. Error reading project file(s).
ERROR: [Project 1-228] Project 'snowleo2' is read-only. To save your work, please use the 'File | Save Project As...' command first.
ERROR: [SDSoC 0-0] Exiting system_linker: Error when calling 'D:/Xilinx/SDSoC/2016.2/Vivado/2016.2/bin/vivado -mode batch -source "C:/Users/huangjianhua/test/new3/SDDebug/_sds/p0/ipi/top.ipi.tcl"'
ERROR: [SDSoC 0-0] Exiting sds++ : Error when calling 'system_linker -cf-input C:/Users/huangjianhua/test/new3/SDDebug/_sds/.llvm/apsys_0.xml -cf-output-dir _sds/p0 -ip-db C:/Users/huangjianhua/test/new3/SDDebug/_sds/.cdb/xd_ip_db.xml -ip-repo C:/Users/huangjianhua/test/new3/SDDebug/_sds/iprepo/repo -sds-pf D:/Xilinx/SDSoC/2016.2/platforms/snowleo2:standalone -software-only -target-os standalone -sdsoc'
sds++ log file saved as C:/Users/huangjianhua/test/new3/SDDebug/_sds/reports/sds.log
ERROR: [SDSoC 0-0] Build failed
make: *** [new3.elf] 错误 1
What exactly do red font errors and warnings mean?
Observer rampage
Re: Error compiling SDSOC project
I guess the reason is that the platform files do not correspond to the SDSOC version one by one.
I now ask the merchant to get the corresponding version of the platform document.
Now the compilation has passed properly.
Thank you for your answer!
Hi @rampage
Kindly share the main.c code or the snippet near line no.134
Best Regards,
Nutan
Observer rampage
