Visitor matteric
Error in project migration from sdaccel 2017.1 to sdaccel 2017.4.op and 2018.2
I am working on migration one project from sdaccel 2017.1 to the new version of 2017.4.op and 2018.2.
under sdaccel 2017.1 env, the hardware simulaiton and deploy-test on board are successfully. But,
under sdaccel 2017.4.op, there is no valid data for signal s_axi_control_awaddr (axi-lite interface) in the hardware simulation, and the generated xclbin file can not feedback results when on-board test;
under sdaccel 2018.2, the following error is reported in the hardware simulation:
./xsim.dir/emu_wrapper_behav/axsim:symbol lookup error: ...../.run/162638/hw_em/device0/binary_0/behav_gdb/xsim/libdpi.so : undefined symbol: _ZN12xcl_api_respC1Ev
simulation engine can not start, code 127
Matt
回复: Error in project migration from sdaccel 2017.1 to sdaccel 2017.4.op and 2018.2
Different SDx releases support different built-in DSAs. Did you target the same DSA? If not, did you run xbinst to install the driver, firmware and runtime libraries for the new DSA?
With regards to the simulation error in 2018.2, how is environment variable $LD_LIBRARY_PATH set?
