Visitor hanqiu
Error using hls stream for global variable
Here is part of my code:
hls::stream<in_type> test_stream;
#pragma HLS STREAM variable=test_stream depth=3
Here is the error message
CRITICAL WARNING: [HLS 200-70] Pragma 'STREAM' (/home/hqiu/systolic_gemm_bi/systolic_gemm_bi.cpp:25) is not inserted at a valid location. Pragma must be inside functions.
Wrong pragma usage.
    while executing
It seems that I can't specify the depth of a global stream and I'm wondering why.
Tags (2)
Re: Error using hls stream for global variable
Hi hanqiu,
Yes, in VHLS you can specify a pragma inside of a function for a global variable.
Please keep in mind that in SDSoC global variables are expressly prohibited except in special circumstances. See UG1027 page 33 where is says:
It is an error to refer to a global variable within a hardware function or any of its sub-functions when this global variable is also referenced by other functions running in software.
The global variable is only allowed when it is referred to entirely within your hardware function and never from the code that will run on the processor.
Sam
Visitor hanqiu
I'm not quite sure, but it seems that I can use pragma in a function to control the global variable
Hi hanqiu,
Sam
