Visitor wind330
Error when using flag "-std=c++11"
Hi:
I have a few source code with c++11 fetures, but when I use the "-std=c++11" compile option, vivado hls report the following error:
D:/Xilinx/SDSoC/2016.1/VIVADO~1/2016.1/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:122:61: error: redefinition of default argument
How can I use "-std=c++11" compile option in SDSoC?
Re: Error when using flag "-std=c++11"
SDSoC does not currently support C++11 in general. SDSoC itself uses Vivado, VivadoHLS, and SDK tools under-the-hood. So if something doesnt work in one of the underlying tools (in this case VivadoHLS) then it will not work in SDSoC either. The various ARM compilers (in SDK) that are used under-the-hood do support c++11, but VivadoHLS does not support c++11 (that I have heard).
According to this post (https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Does-the-latest-HLS-support-C-11-features/td-p/426966) VivadoHLS supports g++ 4.6.
According to this post (http://stackoverflow.com/questions/10363646/compiling-c11-with-g#comment13354800_10363646) g++ 4.6 supports c++11 using the experimental -std=c++0x option.
Dependening on what you are doing your mileage may vary. If you get errors when using VivadoHLS, SDSoC does create VivadoHLS projects under the hood located at <build_cfg>/_sds/vhls/<func_name>. You can always ask HLS specific questions in the other forums to get the attention of the HLS experts.
Scholar stephenm
right click on the application in SDSoC, and select C/C++ build settings. Then under ARM v7 gcc compiler -> Inferred Options -? Software Platform. Add this to the Software Platform Inferred Options
You can also just add this to the make file, if you want
I am using 2018.2 version of sdsoc to run xililnx opencl application.
Here is the command am trying to hardcode.
/tools/xilinx/SDX/SDx/2018.2/SDx/2018.2/bin/xocc -t hw --platform zcu106 --clkid 1 -c -k foo --messageDb binary_container_1/foo.md --xp misc:solution_name=foo --temp_dir binary_container_1 --report_dir binary_container_1/reports --log_dir binary_container_1/logs -std=c++0x -o"binary_container_1/foo.xo" "../src/bar.cpp"
ERROR: option '--target' cannot be specified more than once, type 'xocc -h' for usage info.
make: *** [binary_container_1/foo.xo] Error 1
Note:- The conflict is happening when --target is passed as an argument along with the -std=c++0x (c++11 support)
rajasekhar
