Participant mkaiser
Errors in SDAccel 2018.1 platform development reference design (UG1164)
hi,
I just tried to migrate our DSA to 2018.1 using the reference design. It seems like the associated files for UG 1164 (ug1164-sdaccel-platform-development.zip, link ) have not been updated (both kintex and virtex are affected).
They work fine for 2017.4, but not for 2018.1.
Can you please review this?
from vivado.log, lines 2926 - 2958
ERROR: [IP_Flow 19-3460] Validation failed on parameter 'Const Width(CONST_WIDTH)' for "Const Value is out of range -2147483647:4294967295 allowed by width"
. BD Cell 'static_region/dma_irq_config'
ERROR: [IP_Flow 19-3460] Validation failed on parameter 'Const Val(CONST_VAL)' for Const Value is out of range -2147483647:4294967295 allowed by width
INFO: [IP_Flow 19-3438] Customization errors found on 'static_region/dma_irq_config'. Restoring to previous valid configuration.
INFO: [Common 17-17] undo 'set_property'
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
while executing
"rdi::add_properties -dict {CONFIG.CONST_VAL 6148914689804861440 CONFIG.CONST_WIDTH 32} /static_region/dma_irq_config"
invoked from within
"set_property -dict [ list CONFIG.CONST_VAL {6148914689804861440} CONFIG.CONST_WIDTH {32} ] $dma_irq_config"
(procedure "create_hier_cell_static_region" line 106)
invoked from within
"create_hier_cell_static_region [current_bd_instance .] static_region"
(procedure "create_root_design" line 62)
invoked from within
"create_root_design """
(file "/homes/mkaiser/Projekte/refdesign_xilinx_kcu1500_dynamic_5_0_2018.1/sources/bd/xilinx_kcu1500_dynamic_5_0_static.tcl" line 1993)
while executing
"source ${sourcesDir}/bd/xilinx_kcu1500_dynamic_5_0_static.tcl"
(file "create_design.tcl" line 130)
while executing
"source create_design.tcl"
(file "run.tcl" line 55)
update_compile_order -fileset sources_1
set_property location {179 439} [get_bd_ports PMBUS_ALERT]
undo
INFO: [Common 17-17] undo 'set_property location {179 439} [get_bd_ports PMBUS_ALERT]'
exit
INFO: [Common 17-206] Exiting Vivado at Fri Apr 27 10:44:27 2018...
Visitor kencrocker
Re: Errors in SDAccel 2018.1 platform development reference design (UG1164)
This problem will be solved by modifying the .tcl file
 as follows
Replace:
  # Create instance: dma_irq_config, and set properties
  set dma_irq_config [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant dma_irq_config ]
  set_property -dict [ list \
   CONFIG.CONST_VAL {6148914689804861440} \
   CONFIG.CONST_WIDTH {32} \
 ] $dma_irq_config
with
   CONFIG.CONST_VAL {4294967295} \
 ] $dma_irq_config
The dsa block diagram should build succesfully using 2018.1 after this change.
Ken
Hi @mkaiser
As far as I know, the latest release version of SDx is 2017.4.
So the dsa ref-design should be based on 2017.4, not 2018.1.
Sean
Participant mkaiser
hi seanz,
thank you for your answer. It seems like the package has been revoked. I downloaded Xilinx_SDx_2018.1_0405_1.tar.gz two weeks ago...
Could you check in on that?
edit: checked my installation: see screenshot and xocc version. Now I am kind of confused...
$ xocc -v
** xocc v2018.1 (64-bit)
  ** SW Build 2188600 on Wed Apr  4 18:39:19 MDT 2018
     Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
The package you installed is for SDSoC only.
If you want to use SDAccel you need to roll back to 2017.4.
Sean
Visitor kencrocker
 as follows
Replace:
 ] $dma_irq_config
with
 ] $dma_irq_config
Ken
