GEMX fp64 support
GEMX library seems to have no support for fp64 matrix elements. Only 16-bit integer, 8-bit integer and fp32 are listed in the documentation: https://github.com/Xilinx/gemx/blob/2017.4/gemx/doc/GEMX_ENGINE_UG.md
Is it something that can be enabled now or should be expected in the future releases?
Re: GEMX fp64 support
For FP64, it's too expensive in FPGA and I haven't seen the plan to support it.
Thanks for the info.
