Hardware functions skipped while building in sdx
I am using SDSoC 2017.4 and trying to build matrix multiplication and addition example. When building the project, I don't get any errors, but the build time is strangely short and there are no Vivado synthesis logs or other proof of accelerators being built. It shows following in console
Using prebuilt hardware
Skipping block diagram (BD), address map, port information and device registration for partition 0
It shows almost equal hardware and software timings when I run elf file on Z7-20 board, although estimation cycles in performance estimate report are correct. Can anyone help??
Re: Hardware functions skipped while building in sdx
I have the solution, whenever I check "Estimate Performance" option it only shows me software estimation and does not build hardware functions. When I uncheck this option it builds hardware functions, create block diagram and run synthesis.
Teacher xilinxacct
@kritika117
Here are some thoughts...
1) Could there be a constant that is optimizing out some hardware?
2) Does the schematic show or not show the hardware you think may be missing (and is it connected as expected)?
3) Could you share your project?
Hi @kritika117
Basically, your function is not getting accelerated.
Please let me know which function is accelerated?
This message appears when accelerator is not supported. And there is no warning related to this in 2017.4.
You can use 2018.2/2018.3 in which checks are added if accelerator was generated during linking
Best Regards,
Nutan
@nutang
Thanks for the reply.
None of the functions are accelerated yet. I am trying to accelerate mmult.cpp and madd.cpp functions same as given in matrix multiplication and addition example.
Hello @kritika117
Yes. Then it is expected behavior. Once you accelerate the function, only then you can see the speedup.
Best Regards,
Nutan
@xilinxacct
Thanks for your reply.
No, schematic is not shown.
@nutang
But I am accelerating mmult.cpp and madd.cpp.
Teacher xilinxacct
@kritika117
I guess I would still ask the other 2 questions (and I am curious why no schematic available on an implemented design)...
** Kudos are welcome
Hi @kritika117
Information provided by you is not clear. As per my understanding you have followed below procedure.
1.  Create a new application project
2. Select matrix multiplication and addition example.
3. You can see below hardware function
4. When you give build, you are getting below message in log
Please let me know if my understanding is correct
Best Regards,
Nutan
@nutang
Yes, you are correct. I am exactly doing what you have mentioned in your first three points and getting what you have written in your fourth point.
Hi @kritika117
Thank you for your reply.
I will check and get back to you.
Best Regards,
Nutan
@nutang
I really stuck in this, eagerly waiting for your reply sir.
Thank you for your help so far.
@xilinxacct
1. I don't know about the constant.
3. My project size is larger than the attaching file limit. Hence I could not attach my project file.
