Host code, what is the finish() purpose ?
After the kernel is executed, and the result retrieved, what finish() does ?
I would like to bench the memory transfers, and I wonder if I have to count this one.
回复: Host code, what is the finish() purpose ?
clEnqueue* commands just push commands into command queue, and then immediately return to host. clFinish is to make sure commands in command queue to finish.
FYI.
brucey
FYI.
brucey
Because I would like to do some benchs, especially about memory transfers, hence the code:
clock_gettime(CLOCKTYPE, &ts1);
		//Copy input data to device global memory
		q.enqueueMigrateMemObjects(inBufImg,0);
		int nargs=0;
		sobel.setArg(nargs++,buffer_img_in);
		sobel.setArg(nargs++,buffer_img_out);
clock_gettime(CLOCKTYPE, &ts2);
		//Launch the Kernel
		q.enqueueTask(sobel);
clock_gettime(CLOCKTYPE, &ts3);
		//Copy Result from Device Global Memory to Host Local Memory
		q.enqueueMigrateMemObjects(outBufImg,CL_MIGRATE_MEM_OBJECT_HOST);
		q.finish();
clock_gettime(CLOCKTYPE, &ts4);
I wonder if I have to put the ts4 before or after the q.finish to get a right value.
Put the ts4 after the q.finish to get a right value.
brucey
Ok, thanks for your answers.
