Observer 3dpeter
How to create a new TCF Agent connection in SDx 2018.2?
When I was in SDx2018.2 "debug configuration" window, and tried to make a new TCF connection by entering target name and board ip, and after clicking “test connection” button, I got an error “There is no TCF Agent running on the specified ‘ip address’”.
I am new to FPGA, SDSoC, Xilinx tools and linux, it would be highly appreciated if someone can help.
Detail steps:
1) In SDx 2018.2, mouse right click on the application folder in project explorer -> debug as -> debug configurations -> click "new" button circled in red as below
2) Filled in target name (I'm using zedboard so I used this as target name) and ip of the zedboard, and then clicked "test connection".
3) Then error message appeared as below for zedboard ip.
Things that I have checked as below:
A). After linux boot up finished on zedboard, I can see the "starting tcf-agent: ok" on the Tera Term via UART. (I am not sure if it is correlated)
B)  I can successfully ping the zedboard ip address '127.0.0.1' from MS-DOS prompt on the connected laptop
Re: How to create a new TCF Agent connection in SDx 2018.2?
Hi @3dpeter
Set the IP address of the board.
1.   Set the host's Ethernet address to a static IP (suggested: 192.168.1.10).
2.   In serial console of the board,
Enter the following at the serial port terminal to change the IP address of the board to 192.168.1.11:
ifconfig eth0 192.168.1.11
Note: This can be any address other than the one that the host is configured to.
3. Configure the target connection to communicate to the host PC.
4.  Verify the IP address by entering the following command:
ifconfig eth0
5.   Ping the host using the Linux terminal console to verify connectivity between the host and the target:
ping 192.168.1.10 –c 1
This verifies the Ethernet connectivity between the host and the development board.
Ping should be successful indicated by 0% packet loss.
6.   Return to the SDx tool.
7.   Expand Linux TCF Agent using the Target Connections view.
Optional: If the Target Connections view is not visible, then select Window > Show View > Other > Xilinx > Target Connections and click OK.
8.   Select and right-click Linux Agent [default] and select Edit from the context menu.
Change the host address to 192.168.1.11
Best Regards,
Nutan
Hi @3dpeter,
127.0.0.1 is a local IP for every machine, so if you ping this address from your Windows machine, it doesn't check the connection to your board. If your board is connected directly to your machine thru a ethernet cable, then you can assign it a IP by running this command on the board
ifconfig eth0 192.168.0.1 up
Then you need to assign similar IP (ex. 192.168.0.2) to your host machine from TCP/IPv4 settings. After this, check the connection b/w the board and host thru ping
Hi @3dpeter
ifconfig eth0
Best Regards,
Nutan
Observer 3dpeter
Hi Sadanan and nutang,
It works after I changed board ip and laptop ip to 192.168.1.x per your instructions, thank you.
Participant moritzatconti
I followed your steps to set up the static iP-adresses but I don't get a response when trying to ping my host from the board (the other direction is successful).
What could be the issue for this?
Thanks alot
