How to fix the ERROR: [BD 5-336] This command cannot be run, as the BD-design is locked?
I am a newcomer to the SDSoC development environment. Currently, I am learning to use the reVision platform to accelerate the process of video on the website "http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.4+rev2".According to each step when I downloaded the platform which is given. but gotting the following error information. Please tell me how to solve this problem in the zcu102-rv-ss-2017-4-rev2 platform? Due to the given platform which is not exsit the hardware vivado project, how to run report_ip_status, Thank you very much!
===>The following messages were generated while creating FPGA bitstream. Log file:/home/j/Downloads/rvss/bil_fil/Debug/_sds/p0/_vpl/ipi/vivado.log :
ERROR: [VPL 5-336] This command cannot be run, as the BD-design is locked. Locked reason(s):
* Block design contains locked IPs. Please run report_ip_status for more details and recommendations on how to fix this issue.
List of locked IPs:
zcu102_rv_ss_v_proc_ss_scaler_0
zcu102_rv_ss_v_mix_0_0
zcu102_rv_ss_v_proc_ss_scaler_1
zcu102_rv_ss_mipi_csi2_rx_subsystem_0_0
zcu102_rv_ss_v_proc_ss_csc_0
ERROR: [VPL 60-341] Hardware accelerator integration failed. Aborting build_system. The following log file is available for debugging '/home/j/Downloads/rvss/bil_fil/Debug/_sds/p0/_vpl/ipi/vivado.log'. Contact your local Xilinx representative and provide the log file for further assistance.
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/opt/Xilinx/SDx/2017.4/bin/vpl --iprepo /home/j/Downloads/rvss/bil_fil/Debug/_sds/iprepo/repo --iprepo /opt/Xilinx/SDx/2017.4/data/ip/xilinx --platform /home/j/Downloads/zcu102_rv_ss/zcu102_rv_ss.xpfm --temp_dir /home/j/Downloads/rvss/bil_fil/Debug/_sds/p0 --output_dir /home/j/Downloads/rvss/bil_fil/Debug/_sds/p0/vpl --input_file /home/j/Downloads/rvss/bil_fil/Debug/_sds/p0/.xsd/top.bd.tcl --target hw --save_temps --kernels w0_xf_bilateralFilter --webtalk_flag SDSoC --remote_ip_cache /home/j/Downloads/rvss/ip_cache '
sds++ log file saved as /home/j/Downloads/rvss/bil_fil/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
Re: How to fix the ERROR: [BD 5-336] This command cannot be run, as the BD-design is locked?
Hi sharpmddr,
The message has everything you need to know:
You need to open the Vivado project for your SDSoC platorm in Vivado, open the BD (block design) and run Report -> IP Status. Then upgrade any of the IPs that are necessary.
Sam
Hi sharpmddr,
Sam
Visitor lishen
Hi, it seems not work in vivado by update the IP as below:
After I click "Upgrade Selected", it says that
After OK, it  still get some error in my SDx, which says:
Attempting to get a license: ap_opencl
WARNING: [VPL 17-301] Failed to get a license for 'ap_opencl'. Explanation: The license feature ap_opencl could not be found.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
Attempting to get a license: ap_sdsoc
Feature available: ap_sdsoc
INFO: [VPL 60-895] Target platform: /home/lishen/deephi/zcu102-rv-ss-2018-2/zcu102_rv_ss/zcu102_rv_ss.xpfm
INFO: [VPL 60-423] Target device: zcu102_rv_ss
INFO: [VPL 60-1032] Extracting DSA to /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vivado/.local/dsa
INFO: [VPL 60-251] Hardware accelerator integration...
Creating Vivado project and starting FPGA synthesis.
WARNING: [VPL 60-1142] Unabled to read data from '/home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vivado/output/generated_reports.log', generated reports will not be copied.
===>The following messages were generated while creating FPGA bitstream. Log file:/home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vivado/vivado.log :
ERROR: [VPL 17-53] User Exception: Project already exists on disk, please use '-force' option to overwrite:
/home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vivado/prj/prj.sim
ERROR: [VPL 60-773] In '/home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vivado/vivado.log', caught Tcl error: ERROR: [Common 17-53] User Exception: Project already exists on disk, please use '-force' option to overwrite:
ERROR: [VPL 60-704] Integration error, problem rebuilding project prj
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/opt/Xilinx2018.2/SDx/2018.2/bin/vpl --iprepo /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/iprepo/repo --iprepo /opt/Xilinx2018.2/SDx/2018.2/data/ip/xilinx --platform /home/lishen/deephi/zcu102-rv-ss-2018-2/zcu102_rv_ss/zcu102_rv_ss.xpfm --temp_dir /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0 --output_dir /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/vpl --input_file /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/p0/.xsd/top.bd.tcl --target hw --save_temps --kernels dpu_cache_sync:dpu_memcpy:dpu_memset:dpu_set_cmd:dpu_set_init:dpu_set_prof:dpu_set_instraddr:dpu_get_instraddr:dpu_get_prof:dpu_set_reset:dpu_connection:dpu_get_finish:dpu_set_finishclr:dpu_set_start:dpu_set_profen:dpu_set_base:dpu_get_base:dpu_get_escnt:dpu_get_status:dpu_get_interrupt:adapter --webtalk_flag SDSoC --remote_ip_cache /home/lishen/deephi/sdx_for_deephi/ip_cache --xp vivado_prop:run.impl_1.strategy=Congestion_SpreadLogic_high --xp "param:compiler.deleteDefaultReportConfigs=false" '
sds++ log file saved as /home/lishen/deephi/sdx_for_deephi/dpucore_zcu102/Debug/_sds/reports/sds.log
makefile:45: recipe for target 'libdpucore_zcu102.so' failed
make: *** [libdpucore_zcu102.so] Error 1
But I get my libdpucore_zcu102.so in my project,  it is very strange and do I solved this IP locked problem? Thank you very much.
Voyager
Voyager
If I understood correctly, you managed to open ther SDx staff in Vivado.
How did you proceed ?
Newbie fadyelgawly
Hello, I had the same problem and upgraded my locked IPs now after I finish on Vivado, how do I go back to SDsoc, or how do I get my design on the board from vivado? I've never used vivado before
Visitor hcyhanson
hey,brother. Can you tell me how to open the zcu102_rv_ss project in vivado? I know one way is open the ‘prj.xpr’ file in SDx-->project-->release-->_sds-->p0-->and so on, however,in this way,I can't find this file. thanks for help.
@fadyelgawly , @hcyhanson
To open the revision platform project, find the zcu102_es2_rv_ss.dsa file. You should be able to find it in this location:
C:\Xilinx\SDx\2018.2\platforms\zcu102-es2-rv-ss-2018-2\zcu102_es2_rv_ss\hw
This dsa file is nothing but a zip file. Simply change the extension to .zip from .dsa
Extract the contents to a folder.
Find the prj folder inside the extracted folder:
zcu102_es2_rv_ss.zip\prj
run rebuild.tcl in vivado.
This is going to rebuild the revision platform vivado project.
