How to install SDSoC 2018.3 on Ubuntu?
I downloaded the Web installer version of SDSoC 2018.3 version to install on my Ubuntu desktop. However, I couldn't find instructions in the user guide on how to install it though. The user guide focuses only on single file download installation instructions. Also, when I double clicked the .BIN file, it's doing nothing. Therefore, the installation is not intuitive either. Can someone help me with the installation process? I've been struggling for the whole day to do this.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1294-sdsoc-rnil.pdf
Venky
Re: How to install SDSoC 2018.3 on Ubuntu?
Hi @kodukulav
In the terminal issue the following command in the directory where the bin file is located,
chmod a+x name_of_file.bin
Then run the .bin file by writing
./name_of_file.bin
If you get a permission error you might have to launch with root privileges using sudo:
 sudo ./name_of_file.bin
Let me know if this works out for you.
Vijoy Sunil Kumar
Product Applications Engineer
- Don't forget to reply, kudo and accept as solution
Hi @kodukulav
./name_of_file.bin
Vijoy Sunil Kumar
Thank you! It's working for me.
