Visitor olevr
How to run OpenCL on zcu104
Can someone please tell me step by step how to build and run a simple OpenCL kernel on the PL of the ZCU104 Ultrascale+?  I am new to FPGAs and I can't find an end-to-end tutorial on this subject.  Please walk me through it!
Thanks!
Re: How to run OpenCL on zcu104
Hello @olevr
I have provided a link to the Xilinx Github, specifically an example project demonstrating Dataflow functionality in OpenCL and a gettign started tutorial. I have also provided a link to UG1027, which will have example projects and reference information on SDSoC and OpenCL.
Xilinx Github Example Project: https://github.com/Xilinx/SDSoC_Examples/tree/master/ocl/getting_started/dataflow_func_ocl
Xilinx Github Getting Started Tutorial: https://github.com/Xilinx/SDSoC-Tutorials
UG1027: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1027-sdsoc-user-guide.pdf
I hope this helps!
Visitor olevr
Hi Timothy,
Thanks for the quick reponse.  I will dig into the resources you suggested.  One more question though:  Should I be using SDx 2019.1 or the new Vitis 2019.2 as my SDK?
The vitis platform for zcu104 will be released soon
If you are not waiting for it , you can build the platform refering to https://github.com/Xilinx/XRT/tree/master/src/platform/zcu104_base
@olevr
Of course, I am more than happy to help.
Those are going to be very helpful in starting to use SDSoC.
To answer your second question, the tutorials I sent to you before are all for Vivado SDSoC. If you want to use Vitis, I will also attach tutorials on creating OpenCL kernels in Vitis!
Xilinx Github Vitis OpenCL Kernel: https://github.com/Xilinx/Vitis-Tutorials
Visitor olevr
Hi Timothy,
The quick start guide that came with my ZCU104 Ultrascale+ evaluation kit tells me that after testing the board and acquiring the licence I should follow the instructions at https://github.com/Xilinx/reVISION-Getting-Started-Guide.  The latest version of the reVISION stack is 2018.3 and it says that I need to download the SDSoC™ Development Environment version 2018.3.
Does this mean that I cannot use the SDx Development Environment 2019.1 I currently have installed on my machine?  Or should I not be starting with the reVISION-Getting-Started-Guide in the first place?
Visitor olevr
Also, I can't find the actual download for the SDSoC Development Environment version 2018.3 from the link SDSoC™ Development Environment.  Can you point me to it?
Visitor olevr
Hi again Timothy,
Please ignore the last two posts.  I've decided I only want to pursue running OpenCL on the zcu104 with the latest development environment: Vitis 2019.2.  I have tried running OpenCL on the zcu104 on previous versions of the SDSoC DE and have been unsuccessful.  I'm hoping that with Vitis 2019.2 I will finally have some success.
So to be clear.  My goal is to use the latest Vitis Development Environment to build and run a simple OpenCL kernel on the PL fabric of the ZCU104, where the host code is run from Petalinux booted from the SD card.
Before I can begin with the Vitis Tutorials I need the zcu104_base platform (referred to here).  When will this be made available?
Also, I am running Ubuntu 18.04.3 LTS.  When I start the Vitis 2019.2 installer, it tells me that only Ubuntu 18.04.1 LTS and 18.01.2 LTS are supported.  Should I revert my Ubuntu to 18.04.2 LTS?
Thanks a lot for your help.
Hello @olevr
One big change from 2018.2 to 2018.3 was the removal of OpenCL platforms.
So, if you want to work on opencl, you need to use 2018.2
You can download SDSoC 2018.2 at
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vitis/archive-sdsoc.html
Here are some examples
https://github.com/Xilinx/SDSoC_Examples/tree/2018.2/ocl
Best Regards,
Nutan
Hi @olevr
Okay.
If you want to try with Vitis 2019.2, it is required to clone XRT which contains zcu104_base
Please go through XRT docu to do setup and reply to us in case of questions
You can continue with your current Ubuntu version.
In case you face issue with installation or build, then you can revert.
Best Regards,
Nutan
