How to use URAM in ,SDAccel-opencl ?
While writing kernels in CPP we have the following pragmas
#pragma HLS RESOURCE variable=a  core=XPM_MEMORY uram // utilizes URAM
This works fine the URAM can be accesed(in CPP) , how to access them in Opencl
What are the attributes for kernels written in opencl??
already tried pragmas in opencl , it does not work
Thankyou
Re: How to use URAM in ,SDAccel-opencl ?
Tool has more optimization options in C/C++ code. For OpenCL, options to use URAM is not supported.
ok  then,
Thank You
