HowTo: Use Vitis to run Linux on PS in UltraScale+
Greetings!
Does ANYONE have a tutorial, procedure or link that describes the Vitis steps needed to get a real Linux kernel up and running on the PS side of an UltraScale+ device?  I need to be able to configure Linux, build the Vitis project and then test it booting from an SD.
Thanks!
-Dave
Re: HowTo: Use Vitis to run Linux on PS in UltraScale+
Hi @dtubbs,
Vitis doesn't Build Linux image. You should use PetaLinux to build a Linux image for your MPSoC (or a least this is the easiest way to do so) and then use Vitis to develop your Linux application for example.
Here it is a couple of PetaLinux related links:
ug1144-petalinux-tools-reference-guide.pdf
PetaLinux_WikiPage
PetaLinux_Build_Tutorial_for_2019.1_WikiPage
Best regards,
Abdallah
