Visitor xy0
Is KU3 board support Vivado HLS?
Re: Is KU3 board support Vivado HLS?
hi @xy0
VHLS supports all the Xilinx FPGAs.
In VHLS, you need to set/select the right part for the FPGA selection.
What is the problem?
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Visitor xy0
The product page is here: http://www.alpha-data.com/dcp/products.php?product=adm-pcie-ku3
Thank you in advance!
hi @xy0
- Hervé
SIGNATURE:
Visitor xy0
Thank you for this quick response! Now I find this part on our server's Vivado HLS!  My local machine's HLS doesn't have this part installed.
But here is another problem:
When I type in the part name, there are several options in the part selection and they have same name, same amount of resource except different "speed".  What does the "speed" stand for and how do I choose?  Screenshot provided below, thanks!!
Checking the ADM KU3 user manual referenced on the link you provided shows "-2 extended" so the part would be the third on your screenshot -> XCKU060-FFVA1156-2-E
Note: SDAccel should also give you that info somewhere and would also be in the VHLS scripts that it generates.
For your other desktop vs server issue, that's probably install or license issue.
- Hervé
SIGNATURE:
Visitor xy0
That's really helpful! Thank you so much!!
