Is it possible to choos among HP ports in SDSoC?
Hi all,
I am wondering if it is posible to choose the HP port assigened to an argument in the accelerator.
for example in the following code  (the accelerator prototype) assigne A,B and E to HP0 and C to HP1 and D and F to HP2.
int accel(float A[N], float  B[N], float  C[N], float  D[N], float  E[N], float  F[N]);
A,B, E -->  HP0
C        -- > HP1
D, F    --> HP2
Mohammad
Re: Is it possible to choos among HP ports in SDSoC?
Hi Mohammad,
There is a way to do this, but its currently undocumented. Theres no guarantee that this will continue to work in the future. But heres how it works in 2016.4. Given the platform tcl API for a platform (im using the zc702 built-in platform):
set pfm [sdsoc::create_pfm zc702.hpfm]
sdsoc::pfm_name        $pfm "xilinx.com" "xd" "zc702" "1.0"
sdsoc::pfm_description $pfm "Zynq ZC702 Board"
sdsoc::pfm_clock       $pfm FCLK_CLK0 ps7 0 false proc_sys_reset_0
sdsoc::pfm_clock       $pfm FCLK_CLK1 ps7 1 false proc_sys_reset_1
sdsoc::pfm_clock       $pfm FCLK_CLK2 ps7 2 true  proc_sys_reset_2
sdsoc::pfm_clock       $pfm FCLK_CLK3 ps7 3 false proc_sys_reset_3
sdsoc::pfm_axi_port    $pfm M_AXI_GP0 ps7 M_AXI_GP
sdsoc::pfm_axi_port    $pfm M_AXI_GP1 ps7 M_AXI_GP
sdsoc::pfm_axi_port    $pfm S_AXI_ACP ps7 S_AXI_ACP
sdsoc::pfm_axi_port    $pfm S_AXI_HP0 ps7 S_AXI_HP
sdsoc::pfm_axi_port    $pfm S_AXI_HP1 ps7 S_AXI_HP
sdsoc::pfm_axi_port    $pfm S_AXI_HP2 ps7 S_AXI_HP
sdsoc::pfm_axi_port    $pfm S_AXI_HP3 ps7 S_AXI_HP
for {set i 0} {$i < 16} {incr i} {
  sdsoc::pfm_irq       $pfm In$i xlconcat
sdsoc::generate_hw_pfm $pfm
Notice that S_AXI_HP0 is the port on the block named ps7.
In your code you can use the sys_port pragma to specify which port you want an argument to be connected to. Heres an example for matrix multiply:
#pragma SDS data sys_port(A:ps7_S_AXI_HP0, B:ps7_S_AXI_HP1)
#pragma SDS data access_pattern(A:SEQUENTIAL, B:SEQUENTIAL, C:SEQUENTIAL)
void mmult_accel (float A[N*N], float B[N*N], float C[N*N]);
Notice that you give the port using the format: <IP>_<PORT> where <IP> is "ps7" and <PORT> is "S_AXI_HP0".
Sam
Hi Mohammad,
Sam
