Is there an ap_int doc page?
I have had a hard time finding descriptions for the functions available for ap_ints.
Re: Is there an ap_int doc page?
I would suggest reading the section on C++ Arbitrary Precision Types in UG902 (starting on page 538 in v2019.1).
@pdiffley
Does the stuff in this help you? https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1278-sdsoc-programmers-guide.pdf
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed. :-)
Here is a link to UG902.
