Observer calibra
Issues installing a k1500 board
The board is detected by linux:
lspci -kvvv
1b:00.0 Serial controller: Xilinx Corporation Device 8638 (prog-if 01 [16450])
                Subsystem: Xilinx Corporation Device 4434
                Physical Slot: 256
                Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
                Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
                Interrupt: pin A routed to IRQ 17
                Region 0: Memory at fcc00000 (32-bit, non-prefetchable) [size=4M]
                Region 1: Memory at fd2f0000 (32-bit, non-prefetchable) [size=64K]
                Capabilities: <access denied>
The installation seems to be correct:
/eda/xilinx/SDx/2017.2/bin/xbinst --platform xilinx:kcu1500:4ddr-xpr:4.0 --destination sdaccel_setup
****** xbinst v2017.2_sdx (64-bit)
  **** SW Build 1972098 on Wed Aug 23 11:34:38 MDT 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: [XBINST 60-895]    Target platform: /eda/xilinx/SDx/2017.2/platforms/xilinx_kcu1500_4ddr-xpr_4_0/xilinx_kcu1500_4ddr-xpr_4_0.xpfm
INFO: [XBINST 60-267] Packaging for PCIe...
INFO: Adding section using: 'xilinx_kcu1500_' (2052429 Bytes)
INFO: [XBINST 60-268] Packaging for PCIe...COMPLETE
INFO: [XBINST 60-667] xbinst has successfully created a board installation directory at /home/denis/sdaccel_setup.
sudo ./install.sh
INFO: Installing firmware for FPGA devices
Found hal zip..ignoring
/tmp/29599/0
Archive:  xclmgmt.zip
  inflating: driver/include/xclerr.h
  inflating: driver/include/xclbin.h
  inflating: driver/xclng/mgmt/mgmt-bit.c
  inflating: driver/xclng/mgmt/mgmt-core.c
  inflating: driver/xclng/mgmt/mgmt-core.h
  inflating: driver/xclng/mgmt/mgmt-cw.c
  inflating: driver/xclng/mgmt/mgmt-i2c.c
  inflating: driver/xclng/mgmt/mgmt-thread.c
  inflating: driver/xclng/mgmt/mgmt-firewall.c
  inflating: driver/xclng/mgmt/mgmt-utils.c
  inflating: driver/xclng/mgmt/mgmt-ioctl.c
  inflating: driver/xclng/mgmt/mgmt-xvc.c
  inflating: driver/xclng/mgmt/mgmt-sysfs.c
  inflating: driver/xclng/mgmt/xvc_pcie_ioctl.h
  inflating: driver/include/xclfeatures.h
 extracting: driver/xclng/mgmt/10-xclmgmt.rules
  inflating: driver/xclng/mgmt/Makefile
  inflating: driver/xclng/include/mgmt-reg.h
  inflating: driver/xclng/include/mgmt-ioctl.h
no makefile found in include
INFO: building kernel mode driver
make -C /lib/modules/2.6.32-696.3.1.el6.x86_64/build M=/tmp/29599/0/driver/xclng/mgmt modules
make[1]: Entering directory `/usr/src/kernels/2.6.32-696.3.1.el6.x86_64'
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-core.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-bit.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-cw.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-i2c.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-thread.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-firewall.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-utils.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-ioctl.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-xvc.o
  CC [M]  /tmp/29599/0/driver/xclng/mgmt/mgmt-sysfs.o
  LD [M]  /tmp/29599/0/driver/xclng/mgmt/xclmgmt.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/29599/0/driver/xclng/mgmt/xclmgmt.mod.o
  LD [M]  /tmp/29599/0/driver/xclng/mgmt/xclmgmt.ko
make[1]: Leaving directory `/usr/src/kernels/2.6.32-696.3.1.el6.x86_64'
INFO: Installing new kernel mode driver xclmgmt version 2017.2.1
  MODPOST 1 modules
make -C /lib/modules/2.6.32-696.3.1.el6.x86_64/build M=/tmp/29599/0/driver/xclng/mgmt modules_install
  INSTALL /tmp/29599/0/driver/xclng/mgmt/xclmgmt.ko
  DEPMOD  2.6.32-696.3.1.el6.x86_64
depmod -a
install -m 644 10-xclmgmt.rules /etc/udev/rules.d
rmmod -s xclmgmt || true
modprobe xclmgmt
/tmp/29599/0
Archive:  xocl.zip
  inflating: driver/xclng/drm/xocl/libxdma.c
  inflating: driver/xclng/drm/xocl/libxdma.h
  inflating: driver/xclng/drm/xocl/xocl_bo.c
  inflating: driver/xclng/drm/xocl/xocl_drv.c
  inflating: driver/xclng/drm/xocl/xocl_sysfs.c
  inflating: driver/xclng/drm/xocl/xocl_drv.h
  inflating: driver/xclng/drm/xocl/xocl_xdma.c
  inflating: driver/xclng/drm/xocl/xocl_xdma.h
  inflating: driver/xclng/drm/xocl/cdev_sgdma.h
  inflating: driver/xclng/drm/xocl/Makefile
 extracting: driver/xclng/drm/xocl/10-xocl.rules
  inflating: driver/xclng/drm/.dir-locals.el
  inflating: driver/xclng/include/xocl_ioctl.h
  inflating: driver/xclng/include/libxdma_api.h
  inflating: driver/xclng/include/drm/drm.h
  inflating: driver/xclng/include/drm/drm_mode.h
make -C /lib/modules/2.6.32-696.3.1.el6.x86_64/build M=/tmp/29599/0/driver/xclng/drm/xocl modules
  CC [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl_sysfs.o
  CC [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl_bo.o
  CC [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl_drv.o
  CC [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl_xdma.o
  CC [M]  /tmp/29599/0/driver/xclng/drm/xocl/libxdma.o
  LD [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl.o
  MODPOST 1 modules
  CC      /tmp/29599/0/driver/xclng/drm/xocl/xocl.mod.o
  LD [M]  /tmp/29599/0/driver/xclng/drm/xocl/xocl.ko
INFO: Installing new kernel mode driver xocl version 2017.2.1
  MODPOST 1 modules
make -C /lib/modules/2.6.32-696.3.1.el6.x86_64/build M=/tmp/29599/0/driver/xclng/drm/xocl modules_install
  INSTALL /tmp/29599/0/driver/xclng/drm/xocl/xocl.ko
depmod -a
install -m 644 10-xocl.rules /etc/udev/rules.d
rmmod -s xocl || true
modprobe xocl
Generating SDAccel runtime environment setup script, setup.sh for bash
Generating SDAccel runtime environment setup script, setup.csh for (t)csh
Two drivers are installed:
[root@femlab4 xbinst]# lsmod
Module                  Size  Used by
xocl                   59619  0
xclmgmt                39483  0
modinfo xocl
filename:       /lib/modules/2.6.32-696.3.1.el6.x86_64/extra/xocl.ko
license:        GPL
author:         Sonal Santan <sonal.santan@xilinx.com>
description:    Xilinx PCIe OpenCL Device Manager
version:        2017.2.1
srcversion:     4841F2FA42B02BF7438C33C
alias:          pci:v000010EEd00004B48sv*sd*bc*sc*i*
alias:          pci:v00001D0Fd00001042sv*sd*bc*sc*i*
alias:          pci:v000010EEd00002808sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004808sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004828sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004908sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006D30sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006A30sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006930sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006830sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004B28sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004A28sv*sd*bc*sc*i*
depends:        drm
vermagic:       2.6.32-696.3.1.el6.x86_64 SMP mod_unload modversions
parm:           poll_mode:Set 1 for hw polling, default is 0 (interrupts) (uint)
parm:           interrupt_mode:0 - MSI-x , 1 - MSI, 2 - Legacy (uint)
parm:           enable_credit_mp:Set 1 to enable creidt feature, default is 0 (no credit control) (uint)
modinfo xclmgmt
filename:       /lib/modules/2.6.32-696.3.1.el6.x86_64/extra/xclmgmt.ko
description:    Xilinx SDx management function driver
version:        2017.2.1
license:        GPL v2
srcversion:     FE22194757916C5326977D6
alias:          pci:v000010EEd00004B47sv*sd*bc*sc*i*
alias:          pci:v000010EEd00002807sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004807sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004827sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004907sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006A2Fsv*sd*bc*sc*i*
alias:          pci:v000010EEd0000692Fsv*sd*bc*sc*i*
alias:          pci:v000010EEd0000682Fsv*sd*bc*sc*i*
alias:          pci:v000010EEd00004B27sv*sd*bc*sc*i*
alias:          pci:v000010EEd00004A27sv*sd*bc*sc*i*
alias:          pci:v000010EEd00006C2Fsv*sd*bc*sc*i*
alias:          pci:v000010EEd00006D2Fsv*sd*bc*sc*i*
depends:
parm:           health_interval:Interval (in sec) after which the health thread is run. (1 = Minimum, 5 = default) (int)
parm:           health_check:Enable health thread that checks the status of AXI Firewall and SYSMON. (0 = disable, 1 = enable) (int)
BUT:
runtime/bin/xbsak query
Linux:2.6.32-696.3.1.el6.x86_64:#1 SMP Thu Apr 20 11:30:02 EDT 2017:x86_64
ERROR: No devices found
sudo sdxsyschk
| Tool Version   : SDAccel System Information Checker V2017.2
| Date   : 2017-10-05
| Time  : 21:50:33.179333
| Host Name     : femlab4.unizar.es
Table of Contents
  1. System and Environment Diagnosis
1.1 Linux OS System Check
1.2 64-bit Architecture Check
1.3 Environment Variables Check
1.4 Motherboard System Info
  1. PCIe Diagnosis
2.1 Xilinx PCIe Device Check
2.2 Device Link Speed Check
2.3 Root Port Speed Check
2.4 Xilinx Kernel Driver Check
2.5 Xilinx DSA-Device Matching Check
  1. Memory Functions (DMA) Testing
3.1 DMA Channel Check
3.2 Zero Data Pattern Transfer Test
3.3 Random Data Transfer Test
3.4 Memory Interface (MIG) Range Test
  1. Summary
Checking Python environment...
Version 2.7.5 (default, Jun 27 2013, 14:17:01)
[GCC 4.8.0]
Your Linux System info is:
LSB Version:      :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Distributor ID:   RedHatEnterpriseServer
Description:       Red Hat Enterprise Linux Server release 6.9 (Santiago)
Release:              6.9
Codename:        Santiago
WARNING: Your version of Red Hat distribution is not officially supported!
The architecture of your system processor is:
 x86_64
PASS: 64-bit system requirement check okay.
 System Information
                Manufacturer: VMware, Inc.
                Product Name: VMware Virtual Platform
                Version: None
Processing PCIe info...
PASS: Found Xilinx PCIe device(s):
Device 0 -
2.2.1 Device Link Speed Check - Device 0
Device 0 -
The link capability is:   PCIe Gen2(5 GT/s) with 32 lanes
The link status is:   PCIe Gen2(5 GT/s) with 32 lanes
PASS: Your card's running transfer rate matches its capabilities.
2.3.1 Root Port Speed Check - Device 0
Root Port speed analysis on Device 0 -
PASS: Your card's running transfer rate matches its root port's running link status rate.
2.4.1 Xilinx Kernel Driver Check - Device 0
Device 0 -
NOTE: The device is expecting  Xilinx XCLDMA driver
ERROR: The kernel driver detected:  NONE! , does not match the device's expected version. Please re-install the driver.
2.5.1 Xilinx DSA-Device Matching Check - Device 0
Device 0 -
PASS: The DSA version is being detected as:  xilinx:kcu1500:4ddr-xpr:3.4
WARNING: The DSA binary cannot be found. Please re-install the firmware files after building your design archive.
Exception(s) found in above PCIe diagnosis sections, DMA analysis will not be performed.
4 Summary
Section                                           | Result
1.1 Linux OS System Check                         | WARNING
1.2 64-bit Architecture Check                     | PASS
1.3 Environment Variables Check                   | NOT RUN
1.4 Motherboard System Info                       | DONE
2.1 Xilinx PCIe Device Check                      | PASS
2.2.1 Device Link Speed Check - Device 0          | PASS
2.3.1 Root Port Speed Check - Device 0            | PASS
2.4.1 Xilinx Kernel Driver Check - Device 0       | ERROR
2.5.1 Xilinx DSA-Device Matching Check - Device 0 | WARNING
3.1 DMA Channel Check                             | NOT RUN
I think that the correct driver is XCLDMA
But it is not installed by xbinst.
What can I do ?
Re: Issues installing a k1500 board
Hi Calibra,
It appears that you have installed driver of xilinx:kcu1500:4ddr-xpr:4.0 but the msc file programmed on board is xilinx:kcu1500:4ddr-xpr:3.4. The two versions do not match.
You need to re-program the board with correct .msc file.
Sean
Visitor andy_fox
How did you program the configuration memory on the board ? (not shown in your sequence but required in the installation process outlined in the 2017_2 user guide). When I set mine to use the 4.0 primary/secondary mcs the driver seems ok. It is as if your board has an incorrect configuration memory.
Hi Calibra,
Sean
