KCU1500 Board Installation Problem
I followed the steps in the SDAccel User Guide to perform the installation for the KCU1500 Card (Appendix J ->Installing the KCU1500 Card). I have completed all the steps from Step 1 to Step 4. I am trying to verify if the board installation (helloworld program) was successful as shown in Step 5. But I get the following error message -
Linux:4.13.0-36-generic:#40~16.04.1-Ubuntu SMP Fri Feb 16 23:25:58 UTC 2018:x86_64
Distribution: Ubuntu 16.04.3 LTS
GLIBC: 2.23
XILINX_OPENCL="/home/username/xilinx_kcu1500_dynamic_5_0/xbinst"
LD_LIBRARY_PATH="/home/username/xilinx_kcu1500_dynamic_5_0/xbinst/runtime/lib/x86_64:/home/username/xilinx_kcu1500_dynamic_5_0/xbinst/runtime/lib/x86_64:/home/username/xilinx_kcu1500_dynamic_5_0/xbinst/runtime/lib/x86_64:/opt/Xilinx/SDx/2017.4/lib/lnx64.o/Ubuntu:/opt/Xilinx/SDx/2017.4/lib/lnx64.o:/opt/Xilinx/SDx/2017.4/runtime/lib/x86_64:/usr/local/cuda-9.1/lib:"
ERROR: No devices found
Error: Failed to find an OpenCL platform!
Test failed
Also, the hardware manager on Vivado is able to see the device. I am not sure where I went wrong or what I am missing as I followed all the instructions step-by-step. Please help me resolve this issue.
Thanks!
Re: KCU1500 Board Installation Problem
The KCU1500 board was in a PCIe x8 slot but needs a PCIe x16 slot which was used by my Nvidia GPU. So, I swapped PCI slots with my Nvidia GPU and it works now.
$ /opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/test/verify.exe /opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/test/verify.xclbin
Linux:4.13.0-37-generic:#42~16.04.1-Ubuntu SMP Wed Mar 7 16:03:28 UTC 2018:x86_64
Distribution: Ubuntu 16.04.4 LTS
GLIBC: 2.23
XILINX_OPENCL="/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst"
LD_LIBRARY_PATH="/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/runtime/lib/x86_64:/opt/Xilinx/SDx/2017.4/lib/lnx64.o/Ubuntu:/opt/Xilinx/SDx/2017.4/lib/lnx64.o:/opt/Xilinx/SDx/2017.4/runtime/lib/x86_64:/usr/local/cuda-9.1/lib:"
CL_PLATFORM_VENDOR Xilinx
CL_PLATFORM_NAME Xilinx
Get 1 devices
Using 1th device
loading /opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/test/verify.xclbin
RESULT:
Hello World
Hi @njbenann
Please post the log of step 1~4 so that others may understand your problem.
Hello @seanz, This post is a duplicate of the post here. The logs are in that post.
GLIBC: 2.23
Get 1 devices
Using 1th device
RESULT:
Hello World
I followed the steps in the SDAccel User Guide to perform the installation for the KCU1500 Card (Appendix J ->Installing the KCU1500 Card). But there is a problem in step1: "sudo: xbinst: can't find the command". Can you tell me how to solve this problem? Thank you very much.
