KCU1500 driver compilation error
We tried to install kcu1500 board on ubuntu16.04 following the ug1023.
We generated the driver files using xbinst command successfully, but we got
the following compilation error. We searched around, but failed to find
much relevant information.  Any suggestions will be appreciated.
INFO: building kernel mode driver
make -C /lib/modules/4.15.0-29-generic/build M=/tmp/1637/0/driver/xclng/xdma modules
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-29-generic'
  CC [M]  /tmp/1637/0/driver/xclng/xdma/libxdma.o
/tmp/1637/0/driver/xclng/xdma/libxdma.c: In function ‘enable_msi_msix’:
/tmp/1637/0/driver/xclng/xdma/libxdma.c:1244:8: error: implicit declaration of function ‘pci_enable_msix’ [-Werror=implicit-function-declaration]
   rv = pci_enable_msix(pdev, xdev->entry, req_nvec);
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target '/tmp/1637/0/driver/xclng/xdma/libxdma.o' failed
make[2]: *** [/tmp/1637/0/driver/xclng/xdma/libxdma.o] Error 1
Makefile:1552: recipe for target '_module_/tmp/1637/0/driver/xclng/xdma' failed
make[1]: *** [_module_/tmp/1637/0/driver/xclng/xdma] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-29-generic'
Makefile:20: recipe for target 'all' failed
make: *** [all] Error 2
ls: cannot access '*.ko': No such file or directory
INFO: Installing new kernel mode driver .ko version modinfo: ERROR: missing module or filename.
Generating SDAccel runtime environment setup script, setup.sh for bash
Generating SDAccel runtime environment setup script, setup.csh for (t)csh
回复: KCU1500 driver compilation error
What is the SDx version?
For 2018.2, the supported Ubuntu OS is:
Ubuntu Linux 16.04.3 LTS (64-bit)
- Linux kernel 4.4.0 is supported
- Ubuntu LTS enablement (also called HWE or Hardware Enablement) is not supported
Please check if the kenel version matches. Also, did you install the package list as documented in UG1238?
Thanks for the suggestions.
We are using Vivado 2017.1 and the right ubuntu version, however the kernel version is not the official one and
it caused the compilation error. After we changed the kernel version, the problem is solved.
Cheng Liu
