Observer skotti
Loop bound is not divisible by vector type uint16 length
Hello everyone!
I have a problem with vector types.  I don't know the right way to address an individual element.
For example:
I have a loop which is:
for (int i = 0; i < 99; i++) {
 <some array computations>
and I want to use int16. Obviously the loop bound is not divisible on 16. I don't want to execute one more operation which will exceed 99 and poison  other values in array. How can I make computations on the other 3 array elements (99/16 = 6, 1875, 6*16 = 96)? Should I use any shift registers or so?
Re: Loop bound is not divisible by vector type uint16 length
Hi @skotti ,
Please have a look at following examples which will help you to understand vector data type usage in SDAccel OpenCL kernel better.
https://github.com/Xilinx/SDAccel_Examples/tree/master/vision/watermarking
https://github.com/Xilinx/SDAccel_Examples/tree/master/vision/median_filter
Khronos OpenCL Reference Guide:
https://www.khronos.org/registry/OpenCL/specs/opencl-1.2.pdf [Chapter: 6.1.6, 6.1.7]
Kali
Hi @skotti
Elements of vector data types can be accessed using numerical indexes as below
Vector data type width,
2 - 0, 1
4 - 0, 1, 2, 3
8 - 0, 1, 2, 3, 4, 5, 6, 7
16 - 0, 1, 2, 3, 4, 5, 6, 7,8, 9, a, A, b, B, c, C, d, D, e, E,f, F
These indexes must be preceded by s or S.
For example:
int16 a ; // If you want to access a 3rd element you can do this way --> a.s2
Kali
Observer skotti
@kalib, so will this be kind of correct pattern ?
__kernel void kernel0(__global int16 *A)
local int16 local_A[7];
for (int i = 0; i < 6; i++){
local_A[i] = A[i];
local_A[7].s1 = A[7].s1;
local_A[7].s2 = A[7].s2;
local_A[7].s3 = A[7].s3;
I mean if it is correct to address a loop with i iterating from new indexes with new step, or step should be 16? I just can't find appropriate examples.
I also noticed that such types as double8 are not accessible yet in sdx environment, I had to declare it by myself as typedef double double8 __attribute__((ext_vector_type(8)));
Are all the access patterns applicable to such kind of type?
And should I declare array the same time in the host code, or it will be mapped automatically to this uint16 when passing to kernel?
Hi @skotti ,
Kali
