Observer kwan.huen
Multiple VCU1525 on Same System
When multiple accelerator cards of same model like the VCU1525 are installed in the same host system, is there a  way to determine which one the host code is talking to programmatically?
I've looked through the current OpenCL API, namely clGetPlatformInfo and clGetDeviceInfo. They do not return the info I am looking for. Is there a way to expose the device level info that is unique to each card installed (e.g., serial number, PCIe BDF, and etc.) via the current OpenCL interface?
Thanks and regards,
kwan
Re: Multiple VCU1525 on Same System
Yes, you are correct.
Actually as a user only call device without plug in and out the card in real-time, it's no need to know which physical card is in use.
You can try the below steps to map the logic number of device to the physical device.
1. xbsak query
   Ex: Vendor 10ee
2. Get the physical information of the device:
   lspci -vd 10ee
    You can see the bus number of the device
3. List all the devices which can be seen in the system:
   xbsak list
   You can see the logic number of the device. Ex: device 0: [0] ; device 1: [1]
The sequence of the device is same as the device scanned in the step 2
Ex: Device 0  -> bus 3
      Device 1  -> bus 4
Observer kwan.huen
So in that case in the host C code
vector<cl::Device> devices = xcl::get_xil_devices();
Assuming I have to FPGA cards in the system, the devices[0] and devices[1] matches the same sequence of "xbsak list" and "lspci". Is it correct?
kwan
Observer kwan.huen
Thanks and that makes sense!
-kwan
