Not able to see the compute unit utilization in kmeans sdaccel example.
I am trying to run the sdaccel example of kmeans algorithm, which is provided in the below link
https://github.com/Xilinx/SDAccel_Examples/tree/master/acceleration/kmeans
I changed the below line in make file
#Select the number of Compute units.
COMPUTE_UNITS:=6
it compiles successfully.
 i am running hardware emulation and my command is as follows
./host_kmeans -i ./data/100 -c ./data/100.gold_c5 -m 5 -n 5 -g 6
It runs also fine. But when i look at the sdaccel_profile_summary.html, below is the output.
Compute Unit Utilization (includes estimated device times)
Device Compute Unit Kernel Global Work Size Local Work Size Number Of Calls Total Time (ms) Minimum Time (ms) Average Time (ms) Maximum Time (ms)
xilinx:xil-accel-rd-ku115:4ddr-xpr:4.0-0 kmeans_1 kmeans 6:1:1 1:1:1 48 1.08953 0.022677 0.0226986 0.023048
It does not show up the 6 compute units utilized here, which i configured in my make file.
Please help me in getting this example to run with more compute units ASAP.
Re: Not able to see the compute unit utilization in kmeans sdaccel example.
Thanks for reporting this issue. This is a bug in Makefile. Please find attached the updated one.
Correct value should be as below:
kmeans_LDCLFLAGS=--nk kmeans:$(COMPUTE_UNITS)
Can you try the same?
-Heera
Hi all,
Please help me with this.. I am struck...
Thanks in advance.
Vinod
-Heera
 kernel_frequency compute units kernel execution time
default 1 117.296 ms
100 6 112.563 ms
The default frequency for kernel depends on the target platform. The platform developer fixes it to a particular value. It is typically 200 or 250Mhz. So, by running the kernel at 100MHz, you are potentially losing half the performance (assuming the computation is not memory bound). One needs to balance kernel frequency when increasing number of compute units.
Amit
