Visitor linuskerk
OpenCL Installable Client Driver Loader
There are 2 questions in this post, somewhat related.
Question 1:
I was trying to get my AWS F1 environment to work on my local Centos machine.
I encountered the following...
AWS FPGA-SDK-INFO: /etc/OpenCL/vendors/xilinx.icd does not exist or does not contain lbixilinxopencl.so creating and adding libxilinxopencl.so to it
sh: /etc/OpenCL/vendors/xilinx.icd: No such file or directory
Where can I find lbixilinxopencl.so?
Question 2:
I suspect it has to do with my installation of SDx environment.
I followed the following document.
https://www.xilinx.com/html_docs/xilinx2017_2/sdaccel_doc/topics/platform-mem-model/con-opencl-icd-loader.html
Following the steps to install SDx environment for Centos7 I have a question about step 2.
2. Install the OpenCL SDK RPMs.
linux> rpm -i /proj/picasso/centos/OpenCL-RPMS/*.rpm
I suspect I have a missing RPM. What RPMs is Step 2 referring to?
Linus
Re: OpenCL Installable Client Driver Loader
Hi Linus, Question 1: I have not seen that particular error for AWS yet, but you should be able to locate the libxilinxopencl.so either after running xbinst, or going to to /runtime/lib/x86_64/lib/ Question 2: I am only aware of: opencl-1.2-base-4.4.0.117-1.x86_64.rpm. Do you get an error message while trying to run the RPM install in step 2? Could you provide that message? Thanks,
If at first you don't succeed, try redefining success?
Visitor linuskerk
I actually found the file at  /runtime/lib/x86_64/lib/ as you suggested.
It turns out for some reason sudo didn't work when trying to create /etc/OpenCL/vendors/xilinx.icd
I had to be superuser to do that.
The 2nd question is not relevant anymore.
Linus
