Observer kdavis119
OpenCV mat.inl.hpp:2186:39: error: call to member function 'ptr' is ambiguous
I am using SDx 2018.3, targeting a zcu102 using the reVISION stack
I am receiving errors when including opencv core.hpp file
#ifdef __SDSCC__
#undef __ARM_NEON__
#undef __ARM_NEON
#include "opencv2/core.hpp"
#define __ARM_NEON__
#define __ARM_NEON
#else
#endif
The errors I'm seeing are:
'Building file: ../src/testFile.cpp'
'Invoke: SDS++ Compiler'
sds++ -Wall -O0 -g -I"../src" -I../libs/xfopencv/include -IC:/Xilinx/zcu102revision/sw/a53_linux/a53_linux/inc/xfopencv -c -fmessage-length=0 -MT"src/tstFile.o" -Wno-verloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -mstrict-align -hls-target 1 -MMD -MP -MF"src/testFile.d" -MT"src/testFile.o" -o "src/testFile.o" "../src/testFile.o" -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "C:\Xilinx\zcu102revision" -IC:/Xilinx/zcu102revision/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include
Analyzing source for RTL template usage
C:/Xilinx/zcu102revision/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include/opencv2/core/mat.inl.hpp:2186:39: error: call to member function 'ptr' is ambiguous
return *(_Tp*)((SparseMat*)this)->ptr(i0, true, hashval);
Please assist ?
Observer kdavis119
Re: OpenCV mat.inl.hpp:2186:39: error: call to member function 'ptr' is ambiguous
-hls-target 1 was included in the flags.
There were a handful of standard c++ headers above this set of opencv includes.  Reordering the includes so opencv was always the first ones included fixed the problem
Hi @kdavis119
Please add -hls-target 1 in compiler flags and retry.
Best Regards,
Nutan
Observer kdavis119
