Part 'xcu200' is not installed.
I'm on:
~$ lsb_release -a
Description:	Ubuntu 16.04.6 LTS
I have a working SDAccel 2018.2 installation. I can compile and run kcu1500 HW simulation.
I grabbed the 2018.2 Development Shell from https://www.xilinx.com/products/boards-and-kits/alveo/u200.html#2018_2
I extracted the .deb as I don't use a system-wide installation, and put the u200 folder in the platform folder:
$ ls /home/me/Xilinx/SDx/2018.2/platforms/
xilinx_aws-vu9p-f1_dynamic_5_0  xilinx_vcu1525_dynamic_5_1
xilinx_kcu1500_dynamic_5_0 xilinx_u200_xdma_201820_1
$ ls /home/me/Xilinx/SDx/2018.2/platforms/xilinx_u200_xdma_201820_1/
hw  license  sw  xilinx_u200_xdma_201820_1.xpfm
However, when I try to compile a project, I got:
ERROR: [XOCC 200-70] Part 'xcu200' is not installed.
Any idea welcome.
Re: Part 'xcu200' is not installed.
You need to upgrade to XDF edition or above. U200/U250 is not supported in 2018.2 regular release.
@xil_tour
Can you run the following command to see if you are able to see the device?
xocc --list
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1279-sdx-command-utility-reference-guide.pdf#page=45
--Syed
$ xocc --list
plus some others.
Are you running the regular 2018.2 release of SDAccel or 2018.2 XDF edition?
Please note 2018.2 XDF is dedicated to the development of applications for the Alveo cards (U200 and U250).
I'm on:
Xilinx SDx v2018.2 (64-bit)
Can I use it or am I forced to use the XDF version ?
Ok, thanks for your time.
