Problems with linking OpenCV with SDSoC 18.2
Hello there
My problem is the following:
I am trying to link OpenCV with SDSoC 18.2. I have followed the steps from the Xilinx OpenCV User Guide, but it doesn't want to work for some reason.
I use Windows 10 and I would like to run this project on a ZedBoard.
Steps I have done so far:
1) Include path step
I used C:/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/include
2) Link the library step
I used Librarys(-l) with opencv_core, opencv_features2d, opencv_highgui, opencv_imgproc,
and search path(-L)with C:/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib
The program I would like to compile is very simple:
#include <opencv2\opencv.hpp>
using namespace cv;
int main()
	Mat testColour = imread("kep.png", CV_LOAD_IMAGE_UNCHANGED);
	imshow("pine_colour", testColour);
	imwrite("output.jpg", testColour);
	waitKey();
And this is what I receive, while trying to build the project:
(c) Copyright 2012-2018 Xilinx, Inc. All Rights Reserved.
# Tool version  : sds++ 2018.2 SW Build 2258646 on Thu Jun 14 20:04:27 MDT 2018
# Start time    : Tue Aug 28 10:11:38 +0200 2018
# Command line  : sds++ {-LC:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib} --remote_ip_cache C:/Users/rrb12/Desktop/test/ip_cache -o test1.elf ./src/xf_accumulate_image_accel.o ./src/xf_accumulate_image_tb.o -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann -dmclkid 1 -sds-sys-config linux -sds-proc linux -sds-pf zed
# Log file      : C:/Users/rrb12/Desktop/test/test1/Debug/_sds/reports/sds.log
# Journal file  : C:/Users/rrb12/Desktop/test/test1/Debug/_sds/reports/sds.jou
# Report file   : C:/Users/rrb12/Desktop/test/test1/Debug/_sds/reports/sds.rpt
Removing implementation files from previous run
Libraries: opencv_core opencv_imgproc opencv_imgcodecs opencv_features2d opencv_calib3d opencv_flann
Library Paths {C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib} {}
Searching for static library libopencv_core.a
Searching for static library libopencv_imgproc.a
Searching for static library libopencv_imgcodecs.a
Searching for static library libopencv_features2d.a
Searching for static library libopencv_calib3d.a
Searching for static library libopencv_flann.a
Analyzing object files
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xdinfo=alloc --only-section=.xdinfo C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_accel.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xdinfo.xml
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xddata=alloc --only-section=.xddata C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_accel.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xddata.xml
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xdsdata=alloc --only-section=.xdsdata C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_accel.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xf_accumulate_image_accel.o.xml
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xdinfo=alloc --only-section=.xdinfo C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_tb.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xdinfo.xml
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xddata=alloc --only-section=.xddata C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_tb.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xddata.xml
arm-linux-gnueabihf-objcopy -O binary --set-section-flags .xdsdata=alloc --only-section=.xdsdata C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_tb.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.data/xf_accumulate_image_tb.o.xml
C:/Xilinx/SDx/2018.2/bin/build_xd_ip_db -ip_search 0  -sds-pf C:/Users/rrb12/Desktop/test/test1/Debug/.Xil/zed.hpfm    -o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/.cdb/xd_ip_db.xml
INFO: Using user-defined path for XILINX_XD environment variable C:/Xilinx/SDx/2018.2
Using prebuilt hardware
Skipping block diagram (BD), address map, port information and device registration for partition 0
Prepare hardware access API functions
Create accelerator stub functions
Compile hardware access API functions
arm-linux-gnueabihf-gcc       -I C:/Xilinx/SDx/2018.2/target/aarch32-linux/include  -D HLS_NO_XIL_FPO_LIB  -I C:/Xilinx/Vivado/2018.2/include -c  C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.c
C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.c: In function '_p0_cf_framework_open':
C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.c:24:5: warning: implicit declaration of function 'exit' [-Wimplicit-function-declaration]
     exit(-1);
C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.c:24:5: warning: incompatible implicit declaration of built-in function 'exit'
C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.c:24:5: note: include '<stdlib.h>' or provide a declaration of 'exit'
arm-linux-gnueabihf-g++      -I C:/Xilinx/SDx/2018.2/target/aarch32-linux/include  -D HLS_NO_XIL_FPO_LIB  -I C:/Xilinx/Vivado/2018.2/include -c  C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/cf_stub.c
arm-linux-gnueabihf-ar crs C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/libxlnk_stub.a C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/cf_stub.o
Compile accelerator stub functions
arm-linux-gnueabihf-ar crs C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/libtest1.a C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/cf_stub.o
Enable generation of boot files
     exit(-1);
Link application ELF file
arm-linux-gnueabihf-g++     C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_accel.o C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_tb.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.o {-LC:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib} -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann   -L C:/Xilinx/SDx/2018.2/target/aarch32-linux/lib -LC:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/test1.elf
c:/xilinx/sdk/2018.2/gnu/aarch32/nt/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld.exe: warning: libjpeg.so.62, needed by C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
c:/xilinx/sdk/2018.2/gnu/aarch32/nt/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld.exe: warning: libwebp.so.6, needed by C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
c:/xilinx/sdk/2018.2/gnu/aarch32/nt/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld.exe: warning: libpng16.so.16, needed by C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
c:/xilinx/sdk/2018.2/gnu/aarch32/nt/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld.exe: warning: libtiff.so.5, needed by C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_filter@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_get_IHDR@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_create_read_struct@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_simple_progression@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_finish_compress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_write_scanlines@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFReadRGBATile'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeBGRA'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFSetWarningHandler'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_write_image@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeLosslessBGRA'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_std_error@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFSetField'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPDecodeBGRAInto'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_set_quality@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_finish_decompress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFClose'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_compression_strategy@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFReadRGBAStrip'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_stdio_src@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFGetField'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_gray_to_rgb@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_create_write_struct@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_alloc_huff_table@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_error@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_get_io_ptr@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_set_defaults@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_read_scanlines@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_CreateCompress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_interlace_handling@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_write_info@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_palette_to_rgb@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_destroy_read_struct@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFReadEncodedTile'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_read_update_info@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFWriteScanline'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_start_compress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFReadDirectory'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFReadEncodedStrip'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_CreateDecompress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_bgr@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_start_decompress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_destroy_decompress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFIsTiled'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFWriteEncodedStrip'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_IHDR@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFOpen'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_destroy_write_struct@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_expand_gray_1_2_4_to_8@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFSetErrorHandler'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeBGR'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_resync_to_restart@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_rgb_to_gray@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_longjmp_fn@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_create_info_struct@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_destroy_compress@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_calc_output_dimensions@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeLosslessBGR'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_strip_16@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFRGBAImageOK'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPDecodeBGRInto'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFScanlineSize'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_read_header@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `TIFFNumberOfStrips'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_write_fn@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_write_end@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_packing@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_read_info@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_read_image@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `jpeg_stdio_dest@LIBJPEG_6.2'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_read_end@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `WebPGetFeaturesInternal'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_read_fn@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_get_tRNS@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_compression_level@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_swap@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_init_io@PNG16_0'
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so: undefined reference to `png_set_strip_alpha@PNG16_0'
collect2.exe: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++     C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_accel.o C:/Users/rrb12/Desktop/test/test1/Debug/src/xf_accumulate_image_tb.o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/portinfo.o {-LC:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib} -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann   -L C:/Xilinx/SDx/2018.2/target/aarch32-linux/lib -LC:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o C:/Users/rrb12/Desktop/test/test1/Debug/_sds/swstubs/test1.elf'
sds++ log file saved as C:/Users/rrb12/Desktop/test/test1/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
sds++ completed at Tue Aug 28 10:11:58 +0200 2018
Any idea about what am I doing wrong, and what could be the solution?
Re: Problems with linking OpenCV with SDSoC 18.2
All right, I have solved this issue. I was using a wrong OpenCV dir.
Hello,@richardradli
I  have the same problem.
Could you tell me the correct opencv dir?
Much thanks.
Hello!
Here is the link for the working OpenCV
https://github.com/Xilinx/CHaiDNN/tree/master/SD_Card/opencv
And these are the libs that you should use in order to compile the code succesfully
opencv_core
opencv_photo
opencv_videoio
opencv_highgui
opencv_ml
opencv_imgproc
opencv_imgcodecs
opencv_features2d
opencv_calib3d
opencv_flann
change 'C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib/libopencv_imgcodecs.so' to 'C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\opencv\aarch32\lib\libopencv_imgcodecs.so' !
