RTL Kernel hardware emulation hanging
I have xclbin file generated for my own RTL kernel. But when I try to run the kernel by using command ./host it is hanging with the below message
Data Size Total Bytes =4096
Found Platform
Platform Name: Xilinx
XCLBIN File Name: rtl_kernel
INFO: Importing xclbin/rtl_kernel.hw.xilinx_vcu1525_dynamic_5_0.xclbin
Loading: 'xclbin/rtl_kernel.hw.xilinx_vcu1525_dynamic_5_0.xclbin'
It does not make any progress after this step
Re: RTL Kernel hardware emulation hanging
For command line users, the runtime initialization file needs to be created manually.
The file must be named sdaccel.ini and saved in the same directory as the host executable.
For SDx. GUI users, the project manager creates the sdaccel.ini file automatically based on your run configuration and saves it next to the host executable.
Please add the below content in the sdaccel.ini, and check whether the wdb file can be generated properly:
[Emulation]
launch_waveform=batch
WHere do I find the sdaccel.ini file? Do I create it myself...if yes how do I include it in the make flow
