SDACCEL rtl VADD kernel test failing on VCU1525
I am using Xilinx SDACCEL example design for the VADD rtl kernel. I have the xclbin/vwap.hw.xilinx_vcu1525_dynamic_5_0.xclbin created and then executing the below command for HW emulation.
./host xclbin/vadd.hw.xilinx_vcu1525_dynamic_5_0.xclbin
But the TEST is FAILING and I get the following errors after running the above command.
Below is the log in bold. Is my command correct or does the vu1525 expects more arguments. Thanks and appreciate your help.
Data Size Total Bytes =4096
Found Platform
Platform Name: Xilinx
XCLBIN File Name: vwap
INFO: Importing xclbin/vwap.hw.xilinx_vcu1525_dynamic_5_0.xclbin
Loading: 'xclbin/vwap.hw.xilinx_vcu1525_dynamic_5_0.xclbin'
ERROR: Invalid global_argument size for kernel arg
ERROR: clSetKernelArg() for kernel "vwap_sdx_kernel", argument index 0.
ERROR: clSetKernelArg() for kernel "vwap_sdx_kernel", argument index 1.
ERROR: Invalid scalar argument size, expected 4 got 8
ERROR: clSetKernelArg() for kernel "vwap_sdx_kernel", argument index 3.
ERROR: bad kernel argument index 4
ERROR: bad kernel argument index 5
ERROR: bad kernel argument index 6
ERROR: bad kernel argument index 7
ERROR: bad kernel argument index 8
ERROR: Kernel arg 'a' is not set
ERROR: buffer (5) is not resident in device (0)
Error: Result mismatch  i = 2 Software result = 1 Device result = 0
Error: Result mismatch  i = 3 Software result = 2 Device result = 0
Error: Result mismatch  i = 4 Software result = 2 Device result = 0
Error: Result mismatch  i = 5 Software result = 3 Device result = 0
回复: SDACCEL rtl VADD kernel test failing on VCU1525
It looks there's something wrong with setting your custom RTL kernel arguments.
It looks you didn't use the makefile flow.
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/rtl_kernel/rtl_vadd
You may want to follow the steps in "Alternative Execution Flow for Example Applications in Emulation" section for hw emulation.
export LD_LIBRARY_PATH=$XILINX_SDX/runtime/lib/x86_64/:$LD_LIBRARY_PATH
export XCL_EMULATION_MODE=hw_emu
emconfigutil --platform 'xilinx:vcu1525:dynamic' --nd 1
Once the environment has been configured, the application can be executed by
./host
 Note the above github link is applicable to SDx 2018.2.
After executing ./host I get the following error
ERROR: device::load_binary binary target=Bin , no Hw HAL handle
ERROR: No program executable for device.
FYI I used the following make command to build the kernel
make TARGET=hw DEVICES=xilinx_vcu1525_dynamic_5_1 all
Aftre this I do below steps
./host
And get the above error message. Thanks and appreciate your help.
In the make command, you need to change TARGET from hw to hw_emu.
I changed it to hw_emu and performed the below steps & still see the same error.
1. make TARGET=hw_emu DEVICES=xilinx_vcu1525_dynamic_5_0 all
2. export LD_LIBRARY_PATH=$XILINX_SDX/runtime/lib/x86_64/:$LD_LIBRARY_PATH
3. export XCL_EMULATION_MODE=hw_emu
4. emconfigutil --platform 'xilinx:vcu1525:dynamic' --nd 1
5./host
Below is the log
Found Platform
XCLBIN File Name: vadd
INFO: Importing xclbin/vadd.hw_emu.xilinx_vcu1525_dynamic_5_0.xclbin
Loading: 'xclbin/vadd.hw_emu.xilinx_vcu1525_dynamic_5_0.xclbin'
ERROR: device::load_binary binary target=Bin, no Hw HAL handle
Segmentation fault (core dumped)
I gave it a try at my end by running the following command sequentially, i.e. compile and execute the application in hardware emulation mode.
make TARGETS=hw_emu DEVICES=xilinx:vcu1525:dynamic all
make TARGETS=hw_emu DEVICES=xilinx:vcu1525:dynamic check
I received "TEST PASSED" result.
Please change your device as suggested in the github table.
Here's the list of supported DSAs in SDx 2018.2.
xocc --list xdevices
xilinx_kcu1500_dynamic_5_0
xilinx_vcu1525_dynamic_5_2
I tried running the following command, but get the error message
Error message is below
INFO: [XOCC 60-423]   Target device: xilinx_vcu1525_dynamic_5_0
ERROR: [XOCC 60-926] The specified platform does not support Hardware Emulation (Emulation BD and/or HPFM are missing).
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
../../../utility/rules.mk:128: recipe for target 'xclbin/vadd.hw_emu.xilinx_vcu1525_dynamic.xclbin' failed
make: *** [xclbin/vadd.hw_emu.xilinx_vcu1525_dynamic.xclbin] Error 1
You suggested to change my device name. How do I do that?
It looks the targetting device is not compatible with 2018.2.
In my case, xilinx_vcu1525_dynamic_5_2 is targetted (by running the same make command as you).
Are you using 2018.2? Did you download all the files from the most up-to-date repository?
Thanks for the response. yes I am using 2018.2, does 2017.4 support xilinx_vcu1525_dynamic_5_0?
I also downloadd the latest repo from git last week
Yes, xilinx_vcu1525_dynamic_5_0 is supported in 2017.4.
Thanks . I used the below 2 commands and now I get the TEST PASSED message
make TARGET=hw_emu DEVICES=xilinx_vcu1525_dynamic_5_0 check
Now I have my own RTL kernel and used the above 2 commands to compile it and run but get the below meesage.
