SDACCEL waveform issue
I have the wdb file created by running hardware emulation. I then open sdx and open the wdb file by going to
File-> Open-> rtl_kernel.wdb but I cant see anything in the window.
I have a RTL kernel which I run the hardware emulation for.
Am I using the correct method to view the waveform?
Re: SDACCEL waveform issue
Hi, @vinit.apte ,
The way you open wdb file in sdx is correct.
You can try to open it with Vivado Simulator(Refer to UG900)
xsim <name>.wdb -gui
Hi, @vinit.apte ,
Thanks this works
