SDAccel VC707 supporting
Good Day!
Does SDAccel supports VC707 or KC707 boards? If yes what version do I need? If not what can I perform to make boards work under SDAccel software?
Tags (3)
Re: SDAccel VC707 supporting
There was a checkbox for 7 series in form during installation of SDx IDE. That doesn't mean anything for SDAccel support?
That doesn't mean SDAccel support VC707 and it only mean the integrated Vivado will support 7 series device.
Is there any chance to modify Ultrasale examples' source code for SDAccel to run it on Virtex7?
In 2018.2, You need to have your customized platform first, but the flow is complicated and not supported in the forum now.
I suggest you use the supported platform directly as @yashp mentioned.
SDAccel supported hardware are listed on page number 31 of UG1238.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1238-sdx-rnil.pdf
VC707 and KC707 is not supported under SDAccel.
Yash
