Observer urjitmodhia
SDSOC platform creation
Good Afternoon;
I am trying to use a custom created platform which I had created using xilinx development tools.
I have used xilinx Vivado 2018.2 to create the design, .hdf, .dsa, bitstream and .tcl files  for the platform and I have successfully created that too.
I have used Xilinx SDK 2018.2 to create fsbl.elf, BOOT.bin, .bif and lscript.ld (linker script) files and successfully created.
At last I have used Xilinx SDSoC 2018.2 platform to create platform and I successfully created that also without any error. I attached to screenshots for that. you cqn check it below.
But the issue is:- I am not able to see my created platform in the platform selection window during the creation of application project in SDSoC. I have used Xilinx SDSoC Environmental Tutorial UG1236 for this task. but unfortunatly the created platform is not displayed in this window. but i have found my platform in 'ADD CUSTOM PLATFORM' window but not able to use it.
If someone is familiar with this issue please guide me for the same. it is very important for me.
Thank You
Urjit Modhia
Re: SDSOC platform creation
Hey Nutan;
Thank you for your quick response.
The issue is already solved. The problem was occured because of License of SDSoC. I think the tools was not allowing me to proceed further without the License.
BTW thank you once again.
Hi @urjitmodhia
Is there any error when you select your platform ?
Best Regards,
Nutan
Hey Nutan;
