SDSoC C callable library utilization
I have utilized one of the xfopencv examples and accelerated a function, After that, I created a SDx Library project and imported sources for it to be C callable library. While doing that, I gave auto created hdl codes of the aforementioned project to the library project. I also gave the hpp file of the hw function. By this means, I was planning to get an .a library file which includes the features of the ip and I would be able to use it elsewhere. After doing all these, I created a test project and utilized the .a library that I have created and run the same implementation as it was done in the first application project(the one I accelerated without created a library or .a). It was successful but the timing was disaster. On hardware, it takes 35seconds which is awful. I was  planning to get the same timing result as I have obtained without library(it was 1ms). Why would be the reason?
Thanks a lot for your time.
Re: SDSoC C callable library utilization
I solved my issue by creating shared library instead of creating C callable library. Do not use auto generated hardware to create library. At that time, you won't be able to control it.
What I understood is that the IP is not being controlled. When we check arraycopy example of Xilinx(https://blog.hackster.io/microzed-chronicles-sdsoc-c-callable-libraries-eb8180e890c8) we can see that at some point, accelerator control can be selected. However, I was not able to set it, I do not know why. After running the test project, I did not get any data_motion_network report too. Then, it means my IP cannot be controlled. Is there a way to set it without changing the IP because IP is auto generated and I don't tend to change it.
