Visitor lis_
SDSoC Profiling
I'm working with SDSoC and want to profile C-Code. At the moment I am using a SDSoC Matrix Multiplication template as C-Code. When I click on Profile as ... -> Local C/C++ Application, I get this error message:
" There are no profiling tool plug-ins installed which are supported by the profiling framework. No profiling will be performed."
Is it possible  that SDSoC doesn't find the path to the plug-in? Or that the plug-in isn't installed correctly?
Or do I have to configure something else before I can do this profiling?
(Version: sdsoc-2014.4)
Re: SDSoC Profiling
SDSoC has its own set of profiling tools that you use a little differently than the standard Eclipse profiling. You should refer to Lab 4 "Introduction to Performance Estimation" from UG1028 to learn more about them.
www.xilinx.com
Re: SDSoC Profiling
www.xilinx.com
