Participant jameshko
SDx 2017.4 new DEVICES
Hello there,
I am trying to compile the example from github
github.com/Xilinx/SDAccel_Examples/
I understand that there are two DEVICES listed:
DEVICES=xilinx:kcu1500:dynamic  or    xilinx:vcu1525:dynamic
However, in my case I have a adm-pcie-8k5 which comprise of KU115-2-FLVA1517E FPGA. While this FPGA is in the same family as XCKU115-2-FLVB2104e (kcu1500), they are arguably different.
Hence, do I need to add a new DEVICES ?
If so, how do I do that?
Thank you.
Re: SDx 2017.4 new DEVICES
Hi, @jameshko ,
ADM-PCIE-8K5 platform is only supported in 2017.2. The DSA is not compatible with Sdx 2017.4 op(or newer).
So in SDx 2017.4 op(or newer) version, this platform cannot be added.
Hi, @jameshko ,
I am currently engaging AlphaData on their DSA5.0 for ADM-PCIE-8K5 . I think some level of technical collaboration from Xilinx would be appreciated. Thank you.
