See3CAM_CU30_CHL_TC_BX reVision Feedthrough 2018.2
Hello, I am using the 2018.2 reVision Stack for ZCU104 eval board. The board came with a e-con Systems See3CAM_CU30_CHL_TC_BX camera. Currently, I am trying to set up a gstreamer pipeline to stream video from the camera out to an HDMI monitor.
I am trying to follow this guide which was developed for the 2017.4 reVision Stack opticalflow application for ZCU104 provided by econ-Systems.
https://www.e-consystems.com/blog/camera/getting-started-with-xilinx-zynq-ultrascale-mpsoc-zcu104-evaluation-kit-and-see3cam_cu30_chl_tc_bx
Their file copying commands are as listed
$ cd /media/card
$ cp libopticalflow.so /usr/lib
$ cp libgstsdxopticalflow.so /usr/lib/gstreamer-1.0
$ cp libgstsdxbase.so /usr/lib/gstreamer-1.0
$ cp libgstsdxallocator.so /usr/lib/gstreamer-1.0
Those listed in the github for the reVision stack for opticalflow
# cp lib/libopticalflow.so /usr/lib
# cp gstreamer-1.0/libgstsdxopticalflow.so /usr/lib/gstreamer-1.0
# cp lib/libgstsdxbase.so /usr/lib/gstreamer-1.0
# cp lib/libgstsdxallocator.so /usr/lib/gstreamer-1.0
These more or less perform the same action.
I then run
video_cmd -S
and I get almost the same list as they do in the econ Systems guide
​VIDEO SOURCE ID VIDEO DEVNODE
HDMI Input 0 /dev/video2
USB Webcam 1 /dev/video4
Virtual Video De 2 /dev/video0
But when I run this to setup the USB webcam
$: video_cmd -s 1 -i 1920×1080@UYVY -X
I get the output
Invalid size '1920×1080@UYVY'
Then I run this to set up
$: video_cmd -d 0 -o 1920×1080@UYVY &
and I get
invalid output specifier '1920×1080@UYVY'
Has anyone gotten the econSystems See3CAM_CU30_CHL_TC_BX working on 2018.2 reVision Stack? Thanks.
Re: See3CAM_CU30_CHL_TC_BX reVision Feedthrough 2018.2
Hi @johnfrye11,
First, check whether the camera is working using the following pipeline. Also, when the HDMI is used it is best to set your overlay or the render rectangle. Check the following plugin commands. Now, if this works add your Optical flow plugin and check.
For capture,
gst-launch-1.0 v4l2src device=/dev/video4 io-mode="dmabuf" ! "video/x-raw,format=UYVY,width=1920,height=1080,framerate=30/1" ! fpsdisplaysink video-sink="kmssink plane-id=31 bus-id=b00c0000.v_mix fullscreen-overlay=false render-rectangle=<0,0,1920,1080>" sync=false text-overlay=false -v
For full screen ,
gst-launch-1.0 v4l2src device=/dev/video4 io-mode="dmabuf" ! "video/x-raw,format=UYVY,width=1920,height=1080,framerate=30/1" ! fpsdisplaysink video-sink="kmssink plane-id=31 bus-id=b00c0000.v_mix fullscreen-overlay=true" sync=false text-overlay=false -v
Kumar P G
Visitor sury@
Hi @johnfrye11
If you are using HDMI as your display. Please configure your HDMI using the following command.
$ video_cmd -d 1 -o 1920x1080@UYVY &
Run the following gstreamer command and test if the application works
$ gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! \
 "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! \
 queue ! kmssink bus-id=b00c0000.v_mix plane-id=31
Note: The e-con Systems blog is about using the camera with the Display port monitor.
When I try to run this command, this is what I am seeing
root@xilinx:~# video_cmd -S
root@xilinx:~# video_cmd -d 1 -o 1920x1080@UYVY &
[1] 2487
root@xilinx:~# ERROR: Query DV timings failed: Link has been severed
/dev/video2
[1]+ Done video_cmd -d 1 -o 1920x1080@UYVY
When I attempt to run the output command, the screen remains blue. Note however that when the system boots, the HDMI TV I am using is receiving a signal, it is just a blue screen, so there is a connection to the HDMI output. Any ideas on that?
Visitor sury@
hi @johnfrye11
Please run the following gstreamer command
Note: video_cmd is used to configure the source and display. The above gstreamer command is used to launch the camera
sury@
I understand that. I run the command, after having run the commands listed above with the listed output, and get this output.
root@xilinx:~# gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! \
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
But I do not see anything except a blue screen on the HDMI output.
Not sure if you have any idea why that might be happening. Thanks.
Hi @johnfrye11,
For capture,
For full screen ,
Kumar P G
@kumar.pg
The second command you provided does exactly what I want. It sounds like both commands are made to debug so if you are interested, here is the output,
root@xilinx:~# gst-launch-1.0 v4l2src device=/dev/video4 io-mode="dmabuf" ! "video/x-raw,format=UYVY,width=1920,height=1080,framerate=30/1" ! fpsdisplaysink video-sink="kmssink plane-id=31 bus-id=b00c0000.v_mix fullscreen-overlay=false render-rectangle=<0,0,1920,1080>" sync=false text-overlay=false -v
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: display-width = 1360
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: display-height = 768
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: sync = false
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 13, dropped: 0, current: 25.38, average: 25.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 29, dropped: 0, current: 30.00, average: 27.74
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 45, dropped: 0, current: 30.00, average: 28.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 61, dropped: 0, current: 30.00, average: 28.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 76, dropped: 0, current: 30.00, average: 29.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 92, dropped: 0, current: 30.00, average: 29.25
And the second command, which outputs camera to the screen
root@xilinx:~# gst-launch-1.0 v4l2src device=/dev/video4 io-mode="dmabuf" ! "video/x-raw,format=UYVY,width=1920,height=1080,framerate=30/1" ! fpsdisplaysink video-sink="kmssink plane-id=31 bus-id=b00c0000.v_mix fullscreen-overlay=true" sync=false text-overlay=false -v
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 14, dropped: 0, current: 27.53, average: 27.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 30, dropped: 0, current: 30.00, average: 28.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 46, dropped: 0, current: 30.00, average: 29.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 62, dropped: 0, current: 30.00, average: 29.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 78, dropped: 0, current: 30.00, average: 29.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 94, dropped: 0, current: 30.00, average: 29.61
