System Emulation not found!
I am trying to debug the program in emulator whereas in the Application Project Settings, I am unable to see the option for Target as the only option displayed is hardware.
On the project window, Options-> Target: Hardware.
 Besides, the Emulation model: Debug cannot be selected at all.
I don't know the reason for this!
I want to debug the program and observe the waveform on chip scope and I am unable to obtain it, as I am unable to make the emulator selection.
Can someone please help me in this!
Re: System Emulation not found!
HI @hongh,
Thank you. I have posted my question on Embedded Systems/SDSoC Environment and reVISION Stacks board. However, I haven't received any reply. Thereby, I posted here as I require to debug my program. I am clueless!
What's the version of SDx and the operating system?
Could you upload the snapshot of the issue?
Hi @hongh,
I am using SDSoC 2018.2 and Linux operating system. I am unable to debug the program.
Please find the screenshot attached.
Hi, @pranju ,
You should post the SDSoC question in Embedded Systems/SDSoC Environment and reVISION Stacks board, instead of SDAccel board.
In the beginning of your post, you need to clarify the tool your are using, which can help you to find the right person to answer your question in the shortest time.
HI @hongh,
