Visitor krojek
The OpenCL code compiles but it doesn't executes: no opencl platform error: 1001
I followed those instructions to install Xilinx ALVEO u250 FPGA:
Getting Started with Alveo Data Center Accelerator Cards
SDAccel Development Environment
The problem is when I try to excecute any code in software or hardware emulation mode. The OpenCL platform is not detected. I have executed below examples on the Nimbix cloud, so the the problem should be with the installation. Thanks for any suggestions.
Card validation:
$ sudo /opt/xilinx/xrt/bin/xbutil validate
INFO: Found 1 cards
INFO: Validating card[0]: xilinx_u250_xdma_201830_1
INFO: Checking PCIE link status: PASSED
INFO: Starting verify kernel test:
INFO: verify kernel test PASSED
INFO: Starting DMA test
Host -> PCIe -> FPGA write bandwidth = 10979.7 MB/s
Host <- PCIe <- FPGA read bandwidth = 12156.2 MB/s
INFO: DMA test PASSED
INFO: Starting DDR bandwidth test: ..........
Maximum throughput: 47496.378906 MB/s
INFO: DDR bandwidth test PASSED
INFO: Card[0] validated successfully.
INFO: All cards validated successfully.
Software installed:
xilinx-u250-xdma-201830.1_18.04.deb
xilinx-u250-xdma-201830.1-dev_18.04.deb
xrt_201830.2.1.1695_18.04-xrt.deb
Xilinx_SDAccel_2018.3_1207_2324_Lin64.bin
ls /opt/xilinx/
DocNav/         dsa/            platforms/      SDx/            xic/            xrt/
Downloads/      Model_Composer/ SDK/
cat /etc/OpenCL/vendors/xilinx.icd
/opt/xilinx/xrt/lib/libxilinxopencl.so
ls /opt/xilinx/platforms/xilinx_u250_xdma_201830_1/
hw/                             sw/
license/                        xilinx_u250_xdma_201830_1.xpfm
lsb_release -a
LSB Version:    core-9.20170808ubuntu1-noarch:printing-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:        18.04
Codename:       bionic
 Example from a git repository:
Compilation:
~/SDAccel_Examples/getting_started/misc/vadd$ make all TARGET=sw_emu DEVICE=xilinx_u250_xdma_201830_1
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xcpp -I../../..//libs/xcl2 -I/opt/xilinx/xrt/include/ -Wall -O0 -g -std=c++14 -fmessage-length=0 ../../..//libs/xcl2/xcl2.cpp src/host.cpp  -o 'vadd'  -L/opt/xilinx/xrt/lib/ -lOpenCL -lpthread -lrt -lstdc++
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xocc -t sw_emu --platform xilinx_u250_xdma_201830_1 --save-temps --temp_dir ./_x.sw_emu.xilinx_u250_xdma_201830_1  -c -k krnl_vadd -I'src' -o'xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xo' 'src/krnl_vadd.cl'
****** xocc v2018.3 (64-bit)
  **** SW Build 2405991 on Thu Dec  6 23:36:41 MST 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Attempting to get a license: ap_opencl
Feature available: ap_opencl
INFO: [XOCC 60-1306] Additional information associated with this xocc compile can be found at:
        Reports: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/reports/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1
        Log files: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/logs/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1
INFO: [XOCC 60-585] Compiling for software emulation target
Running SDx Rule Check Server on port:38129
INFO: [XOCC 60-895]   Target platform: /opt/xilinx/platforms/xilinx_u250_xdma_201830_1/xilinx_u250_xdma_201830_1.xpfm
WARNING: [XOCC 74-49] Failed to read in file /opt/xilinx/SDx/2018.3/platforms/achromatic during platform validation. - it doesn't appear in the NIMBIX cloud
INFO: [XOCC 60-423]   Target device: xilinx_u250_xdma_201830_1
INFO: [XOCC 60-242] Creating kernel: 'krnl_vadd'
INFO: [XOCC 60-594] Finished kernel compilation
INFO: [XOCC 60-586] Created xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xo
INFO: [XOCC 60-791] Total elapsed time: 0h 0m 11s
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xocc -t sw_emu --platform xilinx_u250_xdma_201830_1 --save-temps --temp_dir ./_x.sw_emu.xilinx_u250_xdma_201830_1  -l  --nk krnl_vadd:1 -o'xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xclbin' xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xo
INFO: [XOCC 60-1306] Additional information associated with this xocc link can be found at:
        Reports: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/reports/link
        Log files: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/logs/link
INFO: [XOCC 60-629] Linking for software emulation target
Running SDx Rule Check Server on port:39787
INFO: [XOCC 60-586] Created xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xclbin
INFO: [XOCC 60-1307] Run completed. Additional information can be found in:
        Guidance: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/reports/link/xocc_link_krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1_guidance.html
        Steps Log File: /home/krojek/SDAccel_Examples/getting_started/misc/vadd/_x.sw_emu.xilinx_u250_xdma_201830_1/logs/link/link.steps.log
INFO: [XOCC 60-791] Total elapsed time: 0h 0m 17s
emconfigutil --platform xilinx_u250_xdma_201830_1 --od ./xclbin/xilinx_u250_xdma_201830_1
****** configutil v2018.3 (64-bit)
INFO: [ConfigUtil 60-895]   Target platform: /opt/xilinx/platforms/xilinx_u250_xdma_201830_1/xilinx_u250_xdma_201830_1.xpfm
emulation configuration file `emconfig.json` is created in ./xclbin/xilinx_u250_xdma_201830_1 directory
 Execution:
~/SDAccel_Examples/getting_started/misc/vadd$ make check TARGET=sw_emu DEVICE=xilinx_u250_xdma_201830_1
cp -rf ./xclbin/xilinx_u250_xdma_201830_1/emconfig.json .
XCL_EMULATION_MODE=sw_emu ./vadd
../../..//libs/xcl2/xcl2.cpp:40 Error calling err = cl::Platform::get(&platforms), error code is: -1001
Makefile:88: recipe for target 'check' failed
make: *** [check] Error 1
Example from SDAccel (cannot compile!):
Compilation:
~/samples/vadd$ make -f sdaccel.mk run_cpu_em
make SDA_FLOW=cpu_emu run_em -f sdaccel.mk
make[1]: Entering directory '/home/krojek/samples/vadd'
xcpp  /opt/xilinx/SDx/2018.3/lib/lnx64.o/Ubuntu/libstdc++.so.6 -L/opt/xilinx/xrt/lib/ -lOpenCL -lstdc++ -lxilinxopencl -lrt -pthread vadd.o -o vadd
vadd.o: In function `cl::detail::ReferenceHandler<_cl_device_id*>::retain(_cl_device_id*)':
/usr/include/CL/cl2.hpp:1479: undefined reference to `clRetainDevice'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_device_id*>::release(_cl_device_id*)':
/usr/include/CL/cl2.hpp:1490: undefined reference to `clReleaseDevice'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_context*>::release(_cl_context*)':
/usr/include/CL/cl2.hpp:1525: undefined reference to `clReleaseContext'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_command_queue*>::release(_cl_command_queue*)':
/usr/include/CL/cl2.hpp:1534: undefined reference to `clReleaseCommandQueue'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_mem*>::retain(_cl_mem*)':
/usr/include/CL/cl2.hpp:1541: undefined reference to `clRetainMemObject'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_mem*>::release(_cl_mem*)':
/usr/include/CL/cl2.hpp:1543: undefined reference to `clReleaseMemObject'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_program*>::release(_cl_program*)':
/usr/include/CL/cl2.hpp:1561: undefined reference to `clReleaseProgram'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_kernel*>::release(_cl_kernel*)':
/usr/include/CL/cl2.hpp:1570: undefined reference to `clReleaseKernel'
vadd.o: In function `cl::detail::ReferenceHandler<_cl_event*>::release(_cl_event*)':
/usr/include/CL/cl2.hpp:1579: undefined reference to `clReleaseEvent'
vadd.o: In function `cl::Platform::getInfo(unsigned int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*) const':
/usr/include/CL/cl2.hpp:2315: undefined reference to `clGetPlatformInfo'
vadd.o: In function `cl::Platform::getDevices(unsigned long, std::vector<cl::Device, std::allocator<cl::Device> >*) const':
/usr/include/CL/cl2.hpp:2346: undefined reference to `clGetDeviceIDs'
/usr/include/CL/cl2.hpp:2352: undefined reference to `clGetDeviceIDs'
vadd.o: In function `cl::Platform::get(std::vector<cl::Platform, std::allocator<cl::Platform> >*)':
/usr/include/CL/cl2.hpp:2475: undefined reference to `clGetPlatformIDs'
/usr/include/CL/cl2.hpp:2481: undefined reference to `clGetPlatformIDs'
vadd.o: In function `cl::Context::Context(cl::Device const&, long*, void (*)(char const*, void const*, unsigned long, void*), void*, int*)':
/usr/include/CL/cl2.hpp:2689: undefined reference to `clCreateContext'
vadd.o: In function `cl::Buffer::Buffer(cl::Context const&, unsigned long, unsigned long, void*, int*)':
/usr/include/CL/cl2.hpp:3670: undefined reference to `clCreateBuffer'
vadd.o: In function `cl::Program::Program(cl::Context const&, std::vector<cl::Device, std::allocator<cl::Device> > const&, std::vector<std::pair<void const*, unsigned long>, std::allocator<std::pair<void const*, unsigned long> > > const&, std::vector<int, std::allocator<int> >*, int*)':
/usr/include/CL/cl2.hpp:6197: undefined reference to `clCreateProgramWithBinary'
vadd.o: In function `cl::Kernel::Kernel(cl::Program const&, char const*, int*)':
/usr/include/CL/cl2.hpp:6595: undefined reference to `clCreateKernel'
vadd.o: In function `cl::CommandQueue::CommandQueue(cl::Context const&, cl::Device const&, unsigned long, int*)':
/usr/include/CL/cl2.hpp:6979: undefined reference to `clCreateCommandQueue'
vadd.o: In function `cl::CommandQueue::enqueueMigrateMemObjects(std::vector<cl::Memory, std::allocator<cl::Memory> > const&, unsigned long, std::vector<cl::Event, std::allocator<cl::Event> > const*, cl::Event*) const':
/usr/include/CL/cl2.hpp:7950: undefined reference to `clEnqueueMigrateMemObjects'
vadd.o: In function `cl::CommandQueue::enqueueTask(cl::Kernel const&, std::vector<cl::Event, std::allocator<cl::Event> > const*, cl::Event*) const':
/usr/include/CL/cl2.hpp:8001: undefined reference to `clEnqueueTask'
vadd.o: In function `cl::CommandQueue::finish() const':
/usr/include/CL/cl2.hpp:8224: undefined reference to `clFinish'
vadd.o: In function `std::enable_if<!std::is_pointer<cl::Buffer>::value, int>::type cl::Kernel::setArg<cl::Buffer>(unsigned int, cl::Buffer const&)':
/usr/include/CL/cl2.hpp:5858: undefined reference to `clSetKernelArg'
vadd.o: In function `std::enable_if<!std::is_pointer<int>::value, int>::type cl::Kernel::setArg<int>(unsigned int, int const&)':
vadd.o: In function `int cl::Device::getInfo<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >(unsigned int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*) const':
/usr/include/CL/cl2.hpp:2076: undefined reference to `clGetDeviceInfo'
collect2: error: ld returned 1 exit status
../common/common.mk:124: recipe for target 'vadd' failed
make[1]: *** [vadd] Error 1
make[1]: Leaving directory '/home/krojek/samples/vadd'
../common/common.mk:101: recipe for target 'run_cpu_em' failed
make: *** [run_cpu_em] Error 2
  Compilation of the previous code using the makefile from the git repository:
make all
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xcpp -I./libs/xcl2 -I/opt/xilinx/xrt/include/ -Wall -O0 -g -std=c++14 -fmessage-length=0 -DPTF=1  -DTSK=0  -DNDIM=16  -DMDIM=16  -DLDIM=16  -DTS=100  -DTSRES=1  -DPRC=2  -DX=2 -DV1=2 -DV2=2 -DV3=2 -DH=2  ./libs/xcl2/xcl2.cpp src/host.cpp  -o 'vadd.exe'  -L/opt/xilinx/xrt/lib/ -lOpenCL -lpthread -lrt -lstdc++
./libs/xcl2/xcl2.cpp: In function ‘xcl_world xcl_world_single(cl_device_type, const char*, const char*)’:
./libs/xcl2/xcl2.cpp:129:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                 for(i = 0; i < num_platforms; i++) {
./libs/xcl2/xcl2.cpp:143:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
./libs/xcl2/xcl2.cpp:153:8: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
  if (i == num_platforms) {
./libs/xcl2/xcl2.cpp:173:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                 for (i=0; i<num_devices; i++) {
./libs/xcl2/xcl2.cpp:188:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                 if (i == num_devices) {
./libs/xcl2/xcl2.cpp:206:49: warning: ‘_cl_command_queue* clCreateCommandQueue(cl_context, cl_device_id, cl_command_queue_properties, cl_int*)’ is deprecated [-Wdeprecated-declarations]
                                             &err);
In file included from /usr/include/CL/opencl.h:47:0,
                 from ./libs/xcl2/xcl2.hpp:50,
                 from ./libs/xcl2/xcl2.cpp:53:
/usr/include/CL/cl.h:1443:1: note: declared here
 clCreateCommandQueue(cl_context                     /* context */,
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xocc -t sw_emu --platform xilinx_u250_xdma_201830_1 --save-temps  -c -k krnl_vadd -I'src' -o'xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xo' 'src/krnl_vadd.cl'
        Reports: /home/krojek/XILINX-soft/cloud/NWP/_x/reports/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1
        Log files: /home/krojek/XILINX-soft/cloud/NWP/_x/logs/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1
Running SDx Rule Check Server on port:36889
INFO: [XOCC 60-791] Total elapsed time: 0h 0m 12s
mkdir -p ./xclbin
/opt/xilinx/SDx/2018.3/bin/xocc -t sw_emu --platform xilinx_u250_xdma_201830_1 --save-temps  -l  --nk krnl_vadd:1 -o'xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xclbin' xclbin/krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1.xo
        Reports: /home/krojek/XILINX-soft/cloud/NWP/_x/reports/link
        Log files: /home/krojek/XILINX-soft/cloud/NWP/_x/logs/link
Running SDx Rule Check Server on port:38933
        Guidance: /home/krojek/XILINX-soft/cloud/NWP/_x/reports/link/xocc_link_krnl_vadd.sw_emu.xilinx_u250_xdma_201830_1_guidance.html
        Steps Log File: /home/krojek/XILINX-soft/cloud/NWP/_x/logs/link/link.steps.log
INFO: [XOCC 60-791] Total elapsed time: 0h 0m 18s
Execution (the same error - no opencl platform!):
:~/XILINX-soft/cloud/NWP$ make check
XCL_EMULATION_MODE=sw_emu ./vadd.exe
platforms.size()=0
Error: Unable to find Target Device xilinx_u250_xdma_201830_1
Makefile:90: recipe for target 'check' failed
Any ideas how to solve the problem with OpenCL platform?
Visitor krojek
Re: The OpenCL code compiles but it doesn't executes: no opencl platform error: 1001
I have installed Ubuntu 16.04 LTS with linux kernel 4.4.0-141-generic and  Xilinx SDx xdf 2018.2. Now it works. I think that there was a problem with the linux kernel version.
please try the following:
1 check if the /etc/OpenCL/vendors/xilinx.icd is exist
 2 check if the xilinx.icd content is libxilinxopencl.so
 3 check the env , if the library path of libxilinxopencl.so is in the env
Min
Visitor krojek
Thanks for your quick response. I have checked all the points:
The file exists:
~$ cat /etc/OpenCL/vendors/xilinx.icd
and the library also exists:
~$ ls /opt/xilinx/xrt/lib/libxilinxopencl.so
The env contains the path:
source /opt/xilinx/xrt/setup.sh
source /opt/xilinx/SDx/2018.3/settings64.sh
~$ echo $LD_LIBRARY_PATH
/opt/xilinx/SDx/2018.3/lib/lnx64.o/Ubuntu:/opt/xilinx/SDx/2018.3/lib/lnx64.o:/opt/xilinx/SDx/2018.3/runtime/lib/x86_64:/opt/xilinx/xrt/lib:
~$ echo $PATH
/opt/xilinx/Model_Composer/2018.3/bin:/opt/xilinx/SDK/2018.3/bin:/opt/xilinx/SDK/2018.3/gnu/microblaze/lin/bin:/opt/xilinx/SDK/2018.3/gnu/arm/lin/bin:/opt/xilinx/SDK/2018.3/gnu/microblaze/linux_toolchain/lin64_le/bin:/opt/xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin:/opt/xilinx/SDK/2018.3/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/opt/xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin:/opt/xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-none/bin:/opt/xilinx/SDK/2018.3/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/xilinx/SDK/2018.3/tps/lnx64/cmake-3.3.2/bin:/opt/xilinx/DocNav:/opt/xilinx/SDx/2018.3/bin:/opt/xilinx/Vivado/2018.3/bin:/opt/xilinx/xrt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
~$ echo $XILINX_SDX
Visitor krojek
