Visitor little_tom
There is an error running the official examples using SDAccel2018.2
Hi:
We use the vcu1525  board, we have successfully installed the SDAccel 2018.2 environment, and successfully run the verification program verify.xclbin helloworld.
System version: Ubuntu16.04.5   Linux Kernel version: 4.4.0  RAM: 4g  CPU: i7-6700k license is applied for one month
Run the official example: SDAccel_Examples-2018.2 "Helloworld”, SW simulation can pass, HW always has 7 errors. Compilation can not pass
I really look forward to getting some help. Attachment is the  log file.
回复: There is an error running the official examples using SDAccel2018.2
Please refer to the following similar topic and see if it helps.
https://forums.xilinx.com/t5/SDAccel/SDAccel-2018-2-fail-to-link-libdpi-so/m-p/869847
Visitor little_tom
Thanks,I will have a try!
