Updating KCU1500 Driver
We purchased recently a KCU1500 FPGA card that supports OpenCL. I have seen that the latest SDAccel version that is compliant with this card is the 2018.2. This means that the driver for this FPGA is generated based on this SDAccel version.
Is there any way to get updates for the drivers for this card?
Thanking you in advance.
Re: Updating KCU1500 Driver
Currently there is no plan to update shell, driver or XRT for KU1500 board.
