Use of HLS/SDS pragmas in OpenCL kernels
Dear all,
I am exploring some OpenCL kernels using the SDSoC in a Zynq zcu102 platform. I know this board is for SDAccel, but since I'm using OpenCL I believe that my question still applies here.
I am trying to understand how certain optimisations are affecting my codes, thus I wanted to have more control in the HLS generation. I know that the __attribute__(()) is quite useful for defining for example loop unrolling. However, not all HLS/SDS pragmas are available in the __attribute__(()) form. For example, I cannot activate/deactivate loop flatten for a certain loop using the pragmas (as HLS/SDS pragmas are ignored when OpenCL is used, as mentioned in https://forums.xilinx.com/t5/SDAccel/Vivado-HLS-does-not-infer-loop-max-and-min-trip-count-based-on/m-p/879815/highlight/true#M2373).
Is there any way that I could use the pragmas in OpenCL or at least define them in another way? For the loop_flattening for example, I tried to use the set_directive_loop_flatten in a tcl script and then added the "--xp prop:solution.hls_pre_tcl=directives.tcl" arguments to the xocc command line, but I saw no effect in the generated verilog, nor any report message about my changes. The *_csynth.rpt also shows no difference in the latency estimations.
Edit: I also compared using __attribute__((opencl_unroll_hint)) against set_directive_loop_unroll. The first I can successfuly see the loop being unrolled (as expected), while the directive makes no difference at all.
Thank you very much!
回复: Use of HLS/SDS pragmas in OpenCL kernels
HLS pragmas are not supported in opencl kernel.
If you want to fine tune performance, you may choose c++ kernel instead.
brucey
brucey
I know that it is not supported. I just wanted to know if there was anything to overcome this limitation, but apparently not.
Anyway, thanks for the help!
