Using 512 bit length data transfer with OpenCL
I tried to customize the OpenCL Sobel example to use the 512 bit length data transfer, but I ran into this error:
"AP data type can only be used in C++"
Is it possible to do it with another method ?
Re: Using 512 bit length data transfer with OpenCL
Hi @xil_tour ,
There are two ways to address this problem:
1. The problem can be solved by having a structure containing an array of values and applying pragma HLS DATAPACK.
2. Reference Example: https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/kernel_to_gmem/wide_mem_rw_ocl/
Rajat Sarkari
Kindly note- Please mark the Answer as "Accept as solution" if the information provided is helpful.
Hi @xil_tour ,
Rajat Sarkari
Oh, I thought pragmas were reserved to C++ ?
