Vitis integrated SDsoc functionality
Hello!
I have recently downloaded Vitis and I have created XST platform with interfaces (like in sdsoc). And now Im stuck. How can I Make Vititis to accelerate function like in SDSoC because it seems that it doesnt have that option implemented (I couldn't find any way to accelerate SW function)?
Thanks for feedback
PS.  I have found that vitis is creating non-accelerable project so the real question is how can I make accelerable project?
Re: Vitis integrated SDsoc functionality
Hi @bartokon, you may want to run through the SDSoC to Vitis Migration Guide here:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/wzv1561825647931.html
But let us know if you still have issues with accerating the function.
Please don’t forget to reply, kudo, and accept as solution!
Hello!
Thanks for reply.
I have read the information about openCL and followed the steps that you linked.
Now I'm trying to compile a basic program with openCL but another problem has occured.
I have created petalinux platform and linked my libraries, but the compilator gave me an error "/usr/include/CL/cl2.hpp:495:2: error: #error Visual studio 2013 or another C++11-supporting compiler required", I have tried adding libaries like these (screen shots) and added flag -std=c++0x but compilation have failed giving an error "cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C", also compiler gives me an error about namespaces "/usr/include/CL/cl2.hpp:677:1: error: unknown type name ‘namespace’", /usr/include/c++/7/bits/stl_vector.h:68:1: error: unknown type name ‘namespace’ and similar.
Could you tell me how can I change to compiler that supports C++11 and make it compile properly?
Thanks for support!
Screenshot from 2019-11-16 17-22-26.pngScreenshot from 2019-11-16 17-22-42.png
I have found out that I need aarch64-linux-gnu-g++ compiler but it seems that Vitis doesn't have one included? I have changed toolchains and I couldn't find "aarch64-linux-gnu-g++" only "aarch64-linux-gnu-gcc"
On the other hand SDSoC had them included after changing toolchain to Xilinx ARM v8 GNU/Linux Toolchain.
Is there any guide how can I set up Vitis for openCL building from scratch step by step?
Thank you for your patience.
I have made some progress on this matter, this fixed problems with compiler and switched to V8 Arm GNU/Linux toolchain
sudo apt-get install g++-arm-linux-gnueabihf
and now after I added -lOpenCL it says "/home/bartek/HardDrive/Xilinx/Vitis/2019.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/8.2.0/../../../../aarch64-linux-gnu/bin/ld: cannot find -lOpenCL"
Without this -lOpenCL it gaves me an error like this "/home/bartek/HardDrive/Xilinx/Vitis/2019.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/8.2.0/../../../../aarch64-linux-gnu/bin/ld: ./src/main.o: in function `cl::detail::ReferenceHandler<_cl_device_id*>::release(_cl_device_id*)':
/home/bartek/include/CL/cl2.hpp:1491: undefined reference to `clReleaseDevice'"
What should I do next to fix complitation error?
Thank you in advance for your help
Based on the messages, it may be the case that you don't have the required libraries installed/used.
For compilation, please check that the required switches are used for Arm, it mentions using -lxilinxopencl:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk1307139109.html#asy1528754332783
If it doesn't work, please check the installation instructions for the initial libraries needed (it mentions OpenCL):
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk1500615452.html#igz1531201833632
Next, I would check if XRT is installed, as that also includes some libraries used for compilation:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk1858803630.html#dhg1543555360045
Hopefully this helps get your compilation going!
I think that I have problem with platform (Zedboard's) not libraries...
I'm now following this tutorial (https://japan.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk1854106950.html#wxe1570652701297) to create working platform with petalinux and see if the problem is fixed.
