Vitis makefile error
Hello
I have a handoff .xsa file generated from vivado 2019.2.
When i import into vitis and build i get the following:
I am not sure why this happens with a clean directory, fresh handoff file and import.
If I retry the import (meanin delete directory regenerate handoff file and reimport) it works sometimes on the first try and sometimes after 2-3 itterations. Very annoying.
Tags (3)
