Observer skotti
Vivado HLS does not infer loop max and min trip count based on LOOP_TRIPCOUNT pragma in .cl files
Hello everyone!
I can' understand why HLS pragma does not work for me.
I tried this one : #pragma HLS LOOP_TRIPCOUNT
Are there restrictions on scope where  hls tripcount option always works? Or there are some cases when it will not make vivado to infer max and min trip count?
I tried to put it in my examples inside loop body, bit there are still question marks everywhere.
for (int c1 = 1; c1 <= -c0 + 500; c1 += 1) {
#pragma HLS LOOP_TRIPCOUNT min=1 max=499
    for (int c2 = c1; c2 < c0 + c1 - 1; c2 += 1) {
#pragma HLS LOOP_TRIPCOUNT min=1 max=498
trip count is shown as 1~? on the outer loop and ? on the inner loop.
Latency is ? everywhere, I suppose based on the max and minimum number I provided it with it can determine that min and  max latency.
Even in this simple example this pragma does not work...
for (int i = 0; i < c0; i++) {
#pragma HLS LOOP_TRIPCOUNT min=1 max=500
        local_table[i] = table[i];
I also tried to use assertions ( assert(c1 <= 399); ) but sdaccel is complaining about them.
passing '__constant char *' to parameter of type 'const char *' changes address space of pointer
Can I somehow eliminate this error?
Or this kind of trick is not applicable?
Re: Vivado HLS does not infer loop max and min trip count based on LOOP_TRIPCOUNT pragma in .cl files
Hi @skotti ,
SDAccel OpenCL (.cl) looks for only __attribute__ based pragma constructs.
#pragma HLS based pragmas are used in SDAccel (C/C++ - .cpp) based kernels.
Kali
Hi @skotti ,
Kali
Observer skotti
@kalib, for me pragma HLS DATAFLOW also works in .cl files, so I assume that other pragmas should also work.
