Participant bokyung86
What is the difference between CPU Emulation and HW Emulation?
I am very curious about these two differences.
Re: What is the difference between CPU Emulation and HW Emulation?
Hey @bokyung86,
Really depends on the context, but I assume you are referring to SDAccel here ...
For CPU-based emulation, both the host code and the kernel code are compiled to run on an x86 processor. The programmer model of iterative algorithm refinement through fast compile and run loops is preserved with speeds that are the same as a CPU compile and run cycle.
Hardware emulation on the other hand, enables the programmer to check the correctness of the logic generated for the custom compute units. This emulation flow invokes the hardware simulator in the SDAccel environment to test the functionality of the logic that will be executed on the FPGA compute fabric.
Hope this clarifies,
Herbert
Hey @bokyung86,
Herbert
It has helped a lot.
Thank you.
You're welcome!
All the best,
Herbert
