Visitor elfwind
What's the advatange of piped kernels
I am a new OpenCL and SDaccel programmer. I see many people are using pipes to pass data through kernels and I don't know what's the advantage of this.
The kernels kind looks like as follows:
p0
p1
kernel1{
 //read data from host, then write to pipe0
kernel2{
   //read pipe0
   //calculations
   //write pipe1
kernel3{
 //read pipe1
 //write to host
For this kind of use, 3 kernels are used and the maxium kernel number is 10.
Why don't we merge them and do all the things in 1 kernel?
Re: What's the advatange of piped kernels
When you use pipes all the kernels will be running in parallel. Read (P0) and Write (P1) kernels are essentially doing I/O operations for you and Compute kernel operates using P0 - Input and P1-Output
Pipes (Think of a water tap :) ) with a specified width holds the data produced by Read kernel (P0) and it will be consumed by compute kernel and as the compute kernel produces output data which is placed in a different pipe (P1), Write kernel consumes this data and writes back to DDR.
If all the kernels are merged into a single kernel then it becomes sequential. If you want to achieve similar behavior even after merging kernels then you can use dataflow to achieve the same.
Please refer to the example below.
https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/dataflow/dataflow_func_ocl/src/adder.cl
Kali
Kali
Scholar u4223374
There are two reasons:
(1) As @kalib has said, the kernels can all be run in parallel with piped/streaming data. This has big advantages in terms of RAM bandwidth and total throughput. If they were all run sequentially inside a single function, that function would have to store the output from kernel1 until it finished (potentially a very large amount of data), then feed it to kernel2 (and store the output from that until it finished), etc.
(2) You can write all the kernels to run in parallel in a single block, but it tends to get extremely messy for even fairly simple functions. A 3x3 image convolution function is straightforward, fairly neat, and can easily achieve 1 pixel/cycle throughput. Five 3x3 image convolution blocks with each one feeding into the next are really no more complex; you've just got five identical sets of code. They'll still achieve 1 pixel/cycle throughput. On the other hand, a single block that can perform five 3x3 convolutions sequentially on an image and provide 1 pixel/cycle throughput is going to be an extremely complex, error-prone piece of code. It could potentially be smaller if optimized properly, but the greatly increased development time and decreased maintainability will tend to be more of a concern.
Visitor elfwind
Good to know!
To put the I/O operations in a separate function and run in parallel with main kernel seems like a good idea.
I still have 2 questions:
1. Can I merge kernel1 and kernel3 so that I can save 1 CU
2. Further more, what will happen if I use pipes between lots of CUs. For example, use 1 or 2 kernels to feed 8 CUs through pipes.
Will this result in lots of FIFOs directly routing between kernel modules and cause congestion?
Or pipes are actually formed by AXI buses and interconnects. Then these pipes will be time division and the performance may be downgraded.
Which one is right?
Syu
hi @elfwind,
I would suggest if you can give a try to dataflow based implementation as suggested by @kalib:
Design is almost identical to three separate kernels connected through Pipe. Big advantage is that you will get the same performance using single kernel. So you can go upto 10 such instances.
-Heera
Observer ywu1
Pipes are AXI stream FIFOs, point to point. Having 1 CU feeding 8 CUs with PIPEs should be fine provided they aren't huge FIFOs.
