Participant l502418608
XRT install problem
I installed the SDAccel 2018.2,But it does't has the XRT,So I have a question,is it the reason that I can't see any devices?If it is,How can I add the apporiate version XRT?
Re: XRT install problem
You have to make the OS find the FPGA device in advance, then install the driver.
From the lspci -vd 10ee: print, it seems the OS did not detect the two physical functions in your system
after program the FPGA, please try to power cycle you machine. then use lspci to check again
Please download the XRT and DSA on Xilinx website.
https://www.xilinx.com/products/boards-and-kits/alveo/u200.html#gettingStarted
Select "Getting Started" and refer to UG1301.
My Board is KCU1500,Not the U200,and KCU1500 don't have the "Getting Started", Meantime UG1260 don't mention XRT
Hi, @l502418608 ,
Have you downloaded KCU1500 5.0 Platform (ZIP - 495.21 MB)?
https://www.xilinx.com/registration/sign-in.html?oamProtectedResource=wh%3Dwww.xilinx.com%20wu%3D%2Fmember%2Fforms%2Fdownload%2Fxef.html%3Ffilename%3Dplatform_xilinx_kcu1500_dynamic_5_0__20180411.zip%20wo%3D1%20rh%3Dhttps%3A%2F%2Fwww.xilinx.com%20ru%...
Of course I have downloaded the  KCU1500 5.0 Platform,and I also ./xbinst it ,and this is my questions:
XRT Problem
1.If I don't install the XRT,Can I see my device?
2.Why I use xbsak scan I can't see the information about xclmgmt and xocl,What's the problem?
3.Now I installed the XRT,But the problem is as same as the problem2,what should I do?
It should be:
But now it is:
    you can use lspci -vvd 10ee: to check if the devices are detacted and if the driver is loaded
possible reason is he driver did not be installed properly.
please try "xbsak list" , if you can find the device or not
Did you meet any error when build and install the mgmt. driver.
Please try  dmesg  after you build and install the driver, watch if there are any error report
How to install mgmt.driver?I can't see any device using lspci -d 10ee:,I just run the ./xbinst platform.
It's no error When I run the ./install -f yes.like this:Screenshot from 2019-09-03 15-02-05.png
I also reflash the board with the .mcs files ,like this:
But it doesn't works!
I will try again ,Thanks.And I have a problem,Is it using two mcs files of primary.mcs and secondary.mcs to burn into mt25qu512*1*2*4*8 flash? Is this the process of completing the program FPGA?
Now I use the lspci can see my device like this:01:00.0 Memory controller:Xilinx Corporation Device 8038
But I use ./xbsak flash scan still has no device,what's the problem?How to install mgmt.driver?I think I had already installed it like this :IMG_20190908_202235.jpg
I need your help,thanks!
